XP Mini dump crash?
Hi all, not really a editing question, but thought I would post to see if anyone might know a solution.
I have 2 computers (one is my new NLE) and every now and again the system just shuts off and reboots (comp 1, 13 times in the last 3 months, and the new comp 3 time since saturday) and when the system reboots gives me a mini.dmp error message (there is a log file on the computer Minidump, gives you the date and time each happened). Now, I thought this might be a hardware problem on comp #1 (this is a system used for Djing), but since I built Comp #2 (saturday) it's doing the same thing (the piece of harware I though was making this happen is not on the new system), and it happened right in the middle of an editing session. So now I'm thinking it was one of the XP tweeks and tips I adjusted from one of the web pages linked of this forum. That's the only thing these 2 computers have in common, and the only 2 I have ever done these tweeks too. Just wanted to see if anyone has had the same problem, and fixed it. Check on Microsoft Tech Net but found no answers. Thanks for any help Jeff Troiano |
sounds like.........
A registry issue. which may be related to a tweak.....just guessing though.......if it gives you an error code you can track it down.
It may be worth giving MS a call on their customer service line though. I've had good luck with not spending that much time on hold with their customer service number as an FYI.
Dan Holly Anchorage, Alaska |
I had similar troubles on my computer last year. It was self built and after much trouble shooting i identified the problem to be a faulting memory module. If you have more than one module try removing one and see if the problem still occurs, if so swap them over and try again.
Other problems could be the processor is over heating. The power pack is not big enough; there is a website that tells you how to calculate the amount of power each component in your computer uses so you can see if the power pack is over loaded, If i find it again i'll post it here. Which tweak did you do to your computer? is it reversable? Regards Nick |
<<<-- Originally posted by Nick Glenister : The power pack might not be big enough; there is a website that tells you how to calculate the amount of power each component in your computer uses so you can see if the power pack is over loaded, If i find it again i'll post it here.>>>
Values are approx and vary from system to system AGP video card - 20-30W PCI video card - 20W AMD Athlon 900MHz-1.1GHz - 50W AMD Athlon 1.2MHz-1.4GHz - 55-65W Intel Pentium III 800MHz-1.26GHz - 30W Intel Pentium 4 1.4GHz-1.7GHz - 65W Intel Pentium 4 1.8GHz-2.0GHz - 75W Intel Celeron 700MHz-900MHz - 25W Intel Celeron 1.0GHz-1.1GHz - 35W ATX Motherboard - 30W-40W 128MB RAM - 10W 256MB RAM - 20W 12X or higher IDE CD-RW Drive - 25W 32X or higher IDE CD-ROM Drive - 20W 10x or higher IDE DVD-ROM Drive - 20W SCSI CD-RW Drive - 17W SCSI CD-ROM Drive - 12W 5400RPM IDE Hard Drive - 10W 7200RPM IDE Hard Drive - 13W 7200RPM SCSI Hard Drive - 24W 10000RPM SCSI Hard Drive - 30W Floppy Drive - 5W Network Card - 4W Modem - 5W Sound Card - 5W SCSI Controller Card - 20W Firewire/USB Controller Card - 10W Case Fan - 3W LED Case Fan - 6W CPU Fan - 3W |
#5 |
Thanks for all the hints guys, still working on this problem. I think Computer #1's problem has something to do with the sound card. I found the Dump file, download a debug program off of microsoft tech.net load one of the dump file's (couldn't get the program to work right, something about loading symbols) but it refered to my sound card, and I think some sound card file which might be the driver. I unistalled the drivers for the sound card, and downloaded drivers from their web site (was the same drive I was using though) and reinstalled. We'll see if that does the trick. Now as far as computer #2 goes, it hasn't happended again, but I've started reinstalling drivers again to see if that was the ticket, also updated the computers bios, and it hasn't happended since. We'll see though, thanks for the help.
Jeff Troiano |
#6 |
May also prove helpful to see what came up in the Event Monitor. Check each log and, if necessary, do a Google search for the various event IDs and error messages that you'll inevitably find. Also if it blue-screens on you before rebooting or anything, towards the top of the blue-screen try to find any file names, identifiable by the fact that they'll usually have a 3-letter extension following their name. Do a search for that file or files on your computer and on Google. Sometimes they're dead giveaways: nv(something, something).dll. NV is usually Nvidia, which means graphics drivers.
