Motherboard for Intel Core 2 Quad Q6600? (for Sony Vegas) at DVinfo.net
Old August 12th, 2007, 10:00 PM   #1
Images: 32
Any motherboard recommendations for the Intel Core 2 Quad Q6600?
Notes:
For Sony Vegas editing station.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old August 28th, 2007, 01:44 PM   #2
hi Michael
how does the Mobo affect the software???
you should get a mobo that good memory options i.e RAM how much Mhz does it support , Firewire, PCI ports, SATA connections etc. also should be future proof but with Quad Core it might already be ( for Now :) ).
hth :)
Monish Bansal is offline   Reply With Quote
Old August 28th, 2007, 06:09 PM   #3
There are so many different makes and models out there that depend on what your overall goals are for the system. Like Monish said, I'd also recommend getting something with 4 slots for fast RAM, several SATA ports, and at least 2 PCI-Express slots for your video card(s). There are some other motherboard components that are worth looking into as well, such as the north and south bridges. There's a cool article posted in the DIY section on videoguys.com that goes into more explanation, so check them out. Actually, I think they're one of the sponsors for this site, so you might see a banner for them around here...
Shawn McCalip is offline   Reply With Quote
Old August 28th, 2007, 11:34 PM   #4
Images: 32
Sony Vegas can take full advantage of the Q6600 chip, so I want to make sure the motherboard is stable and supports all the features of the CPU.
Old August 29th, 2007, 04:02 PM   #5
I am running the Abit AB9 with my Quad. I run the most current bios(2.0) which is extremely stable! I don't think you can get the regular AB9's anymore, but I know the AB9 Pro is still available at Newegg at a great price. That one also has 10 SATA connectors, an eSATA connector for external and runs raid on both sets of SATA. I actually am looking to upgrade to that board simply for running a larger array and drive options.
The first/original bios for these boards were sort of quirky, but now, it is like a piece of cake(to be honest not that the original that I purchased with wasn't easy, it was just things such as the AHCI in nonraid causing issues) to work with! I know I am getting one before they stop making them because no other board as far as I have seen has as many SATA connectors on it! It's cheap too at 130.00 USD!
The only quirk to the board, which for me and I would think anyone looking to build a system now is the IDE port is at a horrible spot in respect to the rest of the slots for things such as PCI and that nature. But on mine, I don't run anything IDE, so it really doesn't matter. But I for one love the board and am sure I will love my Pro also when I purchase it!
I would recommend downloading the manual and reading through it before purchasing it. Actually for any motherboard to see if everything makes sense to you..
DD
Damon Gaskin is offline   Reply
