Problem with importing images in NewBlue Titler
My friend have this problem: Everytime I import some image in Newblue Titler, the edges of the image are shifted - the part of the top image is on the bottom side and the part of the bottom side of the image is on the top side (same with the left and right side). How do I fix it?
Sponsor: JET DV
Re: Problem with importing images in NewBlue Titler
Are they PNG images? This should not be an issue in Titler Pro 2. I have seen this in Titler Pro 1. My solution is to simply add some additional transparent area to the right and bottom of the image. Then the transparent area will be shifted instead of part of the actual image.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
You are right. 2.0 is ok, but rendering keeps crashing.
Sponsor: JET DV
Pete, please send a note to support at newblueinc dot com stating that I requested you do so so I can send you an updated beta build to test.
#5 |
The problem seems to be in my hardware. I have pretty old graphic card. Nvidia GeForce 8600GT.
#6 |
Sponsor: JET DV
I think it should still work.
