NewBlue Titler Pro updated at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
NewBlueFX plug-ins
Stabilzer, blends, effects and more for Mac & PC editors.
Old October 25th, 2011, 12:00 PM   #1
Sponsor: JET DV
There's now an updated version of Titler Pro available. Just go to the same download page provided by Sony, download the new version (the file name will be the same), and install. You will need the serial number provided by Sony again during installation. This version includes several bug fixes.
Old October 25th, 2011, 12:20 PM   #2
Re: NewBlue Titler Pro updated
Thanks Ed.
Chris J. Barcellos
Old October 25th, 2011, 12:39 PM   #3
Likewise Edward, I'll try this out when I get back home tomorrow. It might be the cure I'm looking for!
TV Director / Cameraman
Old October 25th, 2011, 03:15 PM   #4
where is the sony dl page ;-(
can't for the life of me remember where it was.....
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old October 25th, 2011, 03:24 PM   #5
For Mr Wand!
NewBlue Titler Pro - Titler Software for the Professional Editor's Schedule
Ian Stark is offline   Reply With Quote
Old October 25th, 2011, 06:12 PM   #6
Thank you, Edward. Much appreciated.
Junior Pascual is offline   Reply With Quote
Old October 25th, 2011, 09:45 PM   #7
thanks ian ;-)
still cheesed off - really don't understand....
a. why nb can't use version numbers
b. why, when i click 'check for updates' in about it tells me i have the latest version (111013)
c. the download has no indication of version number either
frankly this is pretty pathetic, even when the titler is terrific.
Old October 26th, 2011, 08:49 AM   #8
Sponsor: JET DV
The build of the new version is 111024. After the update, the "Check for Updates" option will also work correctly which will give you another way to check.
Old October 27th, 2011, 08:53 AM   #9
Sponsor: JET DV
NewBlue uses version/build numbers. Go to Help - About in the titler and you will see the version/build number. The new build number is 111024 so if your build number is lower than that, you are not on the current version.
The "Check for Updates" option in the initial release was pointing to the wrong file. This has been corrected in the new build and will properly function from this point forward.
The file name is the same as the previous file name. There are several reasons behind this. However, it *IS* a new version.
Old October 27th, 2011, 01:45 PM   #10
Ed, question:
The install gave me the Sony Vegas plug-in. It also installed NewBlue Titler Pro Host. The plug-in accepted the serial number that came with VP 11 just fine. But the Host does not like the serial number. It has just informed me I have 5 days left.
What gives?
Adam Stanislav is offline   Reply With Quote
Old October 27th, 2011, 01:47 PM   #11
I've downloaded the new version, but for the life of me, I can't find the serial number for NewBlue Titler in the Sony documentation that was emailed with the download details for Vegas Pro11. The unlock code for Vegas is there, but not for the titler...
I've contacted Sony Creative, but await a reply.
I suppose contacting NewBlue themselves is the next step.
Old October 28th, 2011, 08:38 AM   #12
Sponsor: JET DV
Robin, sony handles the serial number distribution so you will need to contact them for any serial number related issues.
Adam, please uninstall the 111013 build and install the updated 111024 build which started this post. Test Host is not included in the newer build. Test Host is exactly that - a "test" program we used to help determine where some issues were happening. Titler is not designed to be used as a standalone program but, instead, plugs directly into your NLE.
The serial number provided by Sony gets entered into the installation program. Once installed, it will work fine in Vegas Pro 11 without you needing to do any more "activations" or anything else using a serial number.
Edward Troxel is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
