Has anyone tried the 8gb SD card in the HD1 yet ? at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old January 10th, 2007, 04:48 AM   #1
Its pretty darned cheap now but I don't want to buy it without knowing if it works or not and if it does work what happens when you go past 4gb of data in a single clip :-)
You can get one for $96 now !!!
http://www.newegg.com/Product/Produc...82E16820211148
Almost cheap enough for me to impulse buy just to find out if it works or not!
Chris Taylor
http://www.nerys.com/
Chris Taylor is offline
Old January 14th, 2007, 09:17 AM   #2
HD1a working with Transcend SDHC 8GB, I'm tested
Ba Phuong is offline
Old January 14th, 2007, 10:48 AM   #3
Can you reach the end of the 8GB card before your battery runs out? How much of the 8GB is useable on a single charge?
Chris Wells is offline
Old January 14th, 2007, 03:10 PM   #4
what about the original OLED HD1 ??
no the battery will not hold for 8gig it barely holds for 4gig :-) so you will definately need to swap batteries or run on external power. I made a power station for it. first I taped the cradle to my tripod. I rigged up 4 7.2v rc batt packs (3amps each) to give me a 6amp 14.4v source that I ran into a miniature inverter to the camera's power pack to the cradle (all this is taped to the tripod)
I ran the camera for over 3 hours without a problem save the heat warning indicator coming on (though it kept on recording fine)
Chris Taylor
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
