Clamp-On Filter Threads at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old August 18th, 2006, 03:42 PM   #1
I found this on ebay and it fits perfectly, but the problem is that it uses a 36mm filter threads which doesn't have very many options. It's the A36 Filter adapter for the old Leica / Leitz cameras. The one I bought said it was a summitar adapter
("Leica Adapter Summitar Filters to Clamp Mount Elmar").
I've seen several on ebay and other online camera stores. It stays on really well and strong without putting marks on the camera.
http://www.tupware.com/images/sanyoclamp.jpg
Tup Wright is offline
Old August 18th, 2006, 09:20 PM   #2
36mm is not bad at all, use a step-up ring and get to something like 42 or 52mm for a huge selection of filters.
Off to ebay for a filter adaptor.
Bo
www.bophoto.com/HDV
Bo Lorentzen is offline
Old August 19th, 2006, 03:41 AM   #3
I bought an Actina 36mm push on filter from Ebay. This had a UV filter, but it's threaded internally at 34mm. I removed the filter and am using a Kood 34-46mm stepup ring to fit a Sony wideangle lens I've had around for some time. I've used a ring of self amalgamating rubber tape to secure the filter to the camera as an additional support and the whole assembly seems quite stable:
http://www.mltel.com/101_0264.jpg
http://www.mltel.com/101_0263.jpg
Mike Lewis is offline
Old August 19th, 2006, 10:12 AM   #4
How about this adaptor?
I purchased this adaptor from Amazon, and it works perfectly. Well it should, as it's made by Sanyo for this model. It'll allow you to put on any 49mm filter.
http://www.amazon.com/gp/product/B00...lance&n=502394
Rafael Rivera is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
