Tripod at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old June 19th, 2006, 11:25 PM   #1
Tripod
Can you guys suggest a tripod that i can use Xacti HD 1 with a handle? and link where i can buy it
thank you very much
Roman Oulko is offline
Old June 20th, 2006, 09:54 AM   #2
Roman,
Tripods are almost as much a matter of taste as anything else.
Take a look at Samy's website,
http://www.samys.com/product.php?ItemNo=SLIK617505
Here is one which will do the trick. But clearly you can easily spend more on a tripod and still feel you get your moneys worth. More than anything else, you are looking for smooth movements and a stable support for the camera.
If you need to plugin the camera while on the tripod - get one of the tripod adaptors from my website.
Hope this helps.
Bo
www.bophoto.com/HDV
Bo Lorentzen is offline
Old June 20th, 2006, 05:07 PM   #3
I have made the Giottos Q-Pod mini-mini part of my standard HD-1 kit, using it almost all the time. It is less than 4 inches long and less than 4 oz., but just heavy enough to give the camera that little bit of extra heft I find it needs for steady shots. I also use it as a chest pod, and occasionally as an actual tripod on the nearest table or chair back. B&H Photo has them for about $22.
Peter Solmssen is offline
Old June 20th, 2006, 10:06 PM   #4
Thank you guys for all responces . What you think about this one http://www.bhphotovideo.com/bnh/cont...goryNavigation
Old June 20th, 2006, 11:13 PM   #5
You could not find a more inexpensive one..? (smile)
Seriously, Im sure it will hold the camera nicely.! ;-)
Bo
www.bophoto.com/HDV
Old June 21st, 2006, 03:11 AM   #6
I personally don't find that Carson tripod suitable for the HD1 because it has to be carried, rather than pocketed.
Folded Length Approx. 24" (61 cm).
www.irishfilmmaker.com
Graham Jones is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
