HD1 Plug-in for DVD MovieFactory 5 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old May 17th, 2006, 08:56 AM   #1
http://home.businesswire.com/portal/...41&newsLang=en
www.irishfilmmaker.com
Graham Jones is offline
Old May 17th, 2006, 01:44 PM   #2
Graham, have you found the actual download site? I couldn't wade through the Japanese site to find it.
Peter Solmssen is offline
Old May 17th, 2006, 03:37 PM   #3
http://www.google.com/translate?u=ht...&hl=en&ie=UTF8
Old May 22nd, 2006, 05:13 AM   #4
Graham,
Up to now, I have tested the version 4 provided by Sanyo. The problem I got when burning a test DVD was that the video freezes for a few 1/10th of a sec each time a clip is ending...
Any idea? Is it the DVD reader which has some problems to read the DVD-RW?
Should I update to version 5?
Erick Hanoteau is offline
Old May 22nd, 2006, 11:44 AM   #5
Not sure what's causing that Erick - it's not happening for me, so I guess it's not the Ulead software.
I'd suggest searching for reviews to determine whether version 5 is a worthwhile upgrade.
I guess an equivalent of this plug-in for version 5 is already in our version 4, considering it's a 'SANYO SE' version which works with the HD1.
To be honest, I'm surprised how useful the bundled one is and how good the PAL SD DVDs are. Hadn't even installed until recently, simply because I heard it used processing. You do see a little processing but it's minor and I don't think I've burned a better PAL DVD from the HD1 footage any other way.
Old October 9th, 2006, 06:07 AM   #6
Hi,
I have the same "freezing" problem - when creating dvd's out of HD recorded MP4's. Tried with supplied MovieFactory 5.0 SE, MovieFactory 5.0 Plus and Video Studio 10...
Nobody has a clue?
Thanks in advance!
Mircea Crutescu is offline
Old October 9th, 2006, 12:57 PM   #7
maybe because the mp4 is 30fps and my PAL dvd is 25 fps?
Old October 9th, 2006, 03:13 PM   #8
That was it!
Just use NTSC DVD creation...
Old October 9th, 2006, 07:31 PM   #9
Originally Posted by Mircea Crutescu
That was it!
Well, but then you scale it even down to 720x480 resolution only,
which is bad...
Better use MPEG4CAM2AVI first to convert the MP4 toi AVI
and then resample the 30 FPS to 25 frames/sec and 720x576 via
virtualdub.org first or some other interpolation software,
that can handle this framerate and framesize interpolation
and then directly build a PAL DVD from the 720x576 sized AVI !
This then will probably have much better quality.
Regards, Stefan.
Stefan Hartmann is offline
Old October 10th, 2006, 12:47 PM   #10
sounds good ... but how to change the frame rate?
with the basic setup - the resulting avi has the same "jumps"!
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
