Sanyo HD1 footage! - Page 5 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old January 20th, 2006, 12:06 AM   #61
yes.. the whole clip is sony hdr-a1
hdr-hc1 also can perform Similar to this.
this clip is converted to canopus hq codec 4:2:2 and upscale to 1920x1080
http://videopage.net/morita/Hi_Vision/8M_fujiwara.wmv
Jung Kyu is offline
Old January 20th, 2006, 12:22 AM   #62
Very much looking forward to seeing user tests and straight footage from this little camera.
I am a bit heartbroken that there apparently will be no european 25p version.
Also wondering if there is a filter thread on the lens. Perhaps the WA adapter is proprietary? That would also be unfortunate.
Looks pretty good otherwise, though!
Jef Bryant is offline
Old January 20th, 2006, 02:59 AM   #63
Yes, I'm very heartbroken, too. This would have been - as stated before - the perfect lens hack victim.
Just imagin adapting it to Bolex or Beaulieu 16mm c-mount threads and using some nice little 16mm primes on them.
Like a Schneider Kreuznach 1:0.95 25mm
Hellooooo DOF!
And it would look so cool (the 16mm primes are pretty small as well, would keep the form factor).
If the pixels on the 1/2,5 " 5 MP Sensor are too small to have microlens in front of them, the Sanyo may tolerate the wide apperture and this plan could work.
But maybe manufacturing is so advanced now that they can build such a small microlens structure. This would be good for the picture with the build in lens, but very bad for my purpose.
Thomas Richter is offline
Old January 20th, 2006, 03:17 AM   #64
Well finally I managed to see the sample clip. Instead of right clicking and saving as, I had to left click it and open it in WMP. That tricked worked. Thanks.
Now to the footage - WOW! Amazing. Incredible colors, better than any 1 chiper I have seen. And the resolution is amazing as well.
Yes there are artifacts. BUT remeber that this is a VC1 encoded clip and so we don't know which atifacts are associated with which enoding, since it was encoded twice - first by the camera and then by whoever coverted to clip to WMV.
BUT Is this a prank? I mean seriously, how do we know that the Sanyo was really used for this clip??? It looks way too good. Maybe it is not a prank but an error and it is the footage of the Panasonic P2 HD Camera?
Hse Kha is offline
Old January 20th, 2006, 06:02 AM   #65
Original *.mp4 (not reencoded!) clip 1280x720p30 from Sanyo HD1 exist?
Serge Victorovich is offline
Old January 20th, 2006, 08:15 AM   #66
Great Family camera, not an ndie camera
Ok, I think we might be jumping the Gun on this one, sure its a great little camera no disputes there, however for any real inde use I personally can not see it happen, perhaps others may do wonderful things with this camera.
Anhar
The IT Ninja Learn, Teach, Grow..
Anhar Miah is offline
Old January 20th, 2006, 08:59 AM   #67
Just managed to download it, but can't get that WMV format to play properly (works best at 50% speed and drops the ball again at 25%, odd). I had little trouble playing the other HD1 native Mpeg4 clip though, any chance that we could get to see the original, there are a few things I would like to see if Mpeg4 is causing them?
Was this shout in 9Mbps mode or 6Mbps 720p camera mode?
Ok, poor latitude, but might be caused by the codec/player. Seen the dark pants blocking too, maybe also in the face. Sanyo could fix this with firmware change (worth contacting them to let them know). Noticed that big movements, like the hand, the hairs all blur out, codec or low frame rate? Hard to tell, could be media player. Otherwise I am impressed at what they can fit in 9Mbps, but I think h264 at 18-25Mbps would do.
I have found that if you turn use overlays off in the player you get a more natural colour playback, and the edge of colour regions don't appear to change so harshly. There is also a selection on the MS player that turns off video smoothing.
Jung, thanks for putting up the video.
Wayne.
Wayne Morellini is offline
Old January 20th, 2006, 09:13 AM   #68
Lens hacking would only affect the res not the dof. Might be a cool camera for an adapter however.Kurth
Kurth Bousman is offline
Old January 20th, 2006, 09:15 AM   #69
Wayne, try last build MediaPlayerClassic6.4.8.7 or VLC player
Old January 20th, 2006, 09:57 AM   #70
You might, if you can increase the aperture with a SLR lens through a condenser arrangement.
Thanks. Have latest VLC, and WMP, but native mpeg4 works many times better than WMP.
Old January 21st, 2006, 05:35 AM   #71
Yes SLR and condenser is possible, I was thinking of something else:
If you can replace the original lens with a mount for prime lenses, you will get a shallower depth of field IF the primes have very wide apertures (wider than the build in lens).
One example is the Drake cam (see Alternative Imaging methods). They get very shallow 35mm style DOF with a 2/3" sensor using primes with very wide apertures. The only reason they can do this, is because the sensor doesn't have a microlens-array in front of the silicone.
But I don't want to extend this discussion too far. Just imagining how cool this little cam would be with small but fully manual lens for 16mm cameras on it.
Old January 21st, 2006, 05:42 AM   #72
Sorry to tell you, but you can't change the DOF without a ground glass or other intermediate focal plane between the lens and the sensor.
It's just not possible to change DOF with any combination of just lens's.
I doubt that the Sanyo is stopped down much either. They want all the light they can get. So hoping that a F1.2 lens would help is probably
futile. But when you get the Sanyo, are you *really* going to hack it's lens off? Really?
-Les
Les Dit is offline
Old January 21st, 2006, 06:30 AM   #73
Les, you are right. If it comes with a 1.2 lens, it makes no sense at all.
I think I am creating a bit of a misunderstanding. Obviously, the DOF of the camera won't change. What would chance would be the maximum aperture of the lens. That's what I was referring to. The picture of a 1/2,5" imaging sensor at 1.2 would probably have the same DOF as a 35mm film (not photo) stopped down to 8. (Not calculated, just an estimate - I can calculate precisely if requested).
I would have hacked if the following three conditions:
1) PAL version with 25p
2) Aperture of build-in lens >= 1.8
3) live video out (to monitor on an external LCD screen)
As 1) is probably not going to materialise, its purely hypothetical. Anyway, if someone would like to join my dreaming, feel free to email me.
Old January 22nd, 2006, 08:27 AM   #74
Here is a conversation I am having with the akihabaranews guy, about the camera, he is waiting for a review unit.
http://forum.akihabaranews.com/viewt...asc&highlight=
Jung, any chance we can get a copy of that footage in the cameras native format (Media player does nasty things to footage quality, as can be seen from that trans-codec review I posted earlier)?
Wayne.
Old January 30th, 2006, 03:41 PM   #75
Hello all,
with this links you can get the original movie files.
http://china.nikkeibp.co.jp/china/im...060116baby.MP4
http://china.nikkeibp.co.jp/china/im...60116child.MP4
The quality seems much better.
Jony Upper is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
