Sanyo HD1 footage! - Page 12 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old February 16th, 2006, 12:43 PM   #166
Originally Posted by Joseph Aurili
I hooked up the camera to a SD TV via svideo. I don't have a HD TV where I am now. In a dark room I could not tell the difference between the live video and the played back recorded video. When I used a bright light I still did not notice a difference in image quality. I did notice that bright areas of the image would flicker a lot on playback, but would not live.
Joseph, many SD TV's have a resolution closer to 360 pixels across, even through component input (have this problem on my 69CM) even makes MiniDV look good. Svideo tends to be limited to close to 360+ automatically. If your friendly with a store that sells true HD TV's (most have less than 720p) you can waltz in and say, "hey, look what I've got" and ask them if you can hook it up to their TV's through component. A 42 inch is great but 55 inch+ should make it more obvious. Along the lines of what Tom was talking
about, look for more latitude and information in the blacks and highlights.
Wayne Morellini is offline
Old February 16th, 2006, 01:15 PM   #167
http://www.nytimes.com/2006/02/16/te...s/16pogue.html
David Pogue has a write up on the Sanyo in today's NYTimes Feb 16 Technology section.
[Edit] oops.. someone already beat me to it.
John C. Chu is offline
Old February 16th, 2006, 01:29 PM   #168
Wayne, I was just trying to determine if the video output was compressed or not. My 1080i TV is in storage on the other coast :(
Joseph Aurili is offline
Old February 16th, 2006, 01:38 PM   #169
That review is right on.
Old February 16th, 2006, 01:41 PM   #170
Yes I know, it's just the low resolution hides it. That Times article says it pretty well, some of the words sound like ones used here, I wonder if he is reading this.
Old February 16th, 2006, 01:57 PM   #171
That would be funny and sad...
Old February 16th, 2006, 04:40 PM   #172
OK, here is the resolution chart again in auto and manual white balance:
www.gamersden.com/hd1test/chartauto.MP4
www.gamersden.com/hd1test/chartmanual.MP4
A lot better color IMO.
And the chart is better aligned. Does it add some resolution? ;)
Take into account the auto is dealing with 2 or 3 different types of light sources.
Old February 16th, 2006, 04:56 PM   #173
And here are some outdoor clips in overcast lighting with a tripod in the same general area of the first clips to compare. This might be as good as it gets...
www.gamersden.com/hd1test/OC1.MP4
www.gamersden.com/hd1test/OC2.MP4
www.gamersden.com/hd1test/OC3.MP4
www.gamersden.com/hd1test/OC4.MP4
www.gamersden.com/hd1test/OC5.MP4
Old February 16th, 2006, 07:22 PM   #174
My questions and concerns are a little different than the others on this forum. I am hoping I can get some good advice on whether the HD1 will fit my slightly (ok very) different needs.
I don't have a high def camcorder. I have an old RIcoh Hi8 one but it is broken. BTW, the mechanical image stabilization on it was great. I used to shoot stills with a Minolt Maxxum and had about every accessory you could imagine including the dual flash system for portrait work. Then I got married and had kids. The Maxxum got replaced with a Canon ELPH. It doesn't matter how nice the camera if you don't have it with you. Then I went digital with a Ricoh RDC-7. I liked the pictures but the camera was SLOW - slow to power up, slow to focus, slow to release the shutter and slow to write the data. Surprisingly my wife started shooting video on it. At 320x240-15fps I had to ask "Why?" Her answer was "Because it is there and it is all I have." That meant movie mode was an important factor in an upgrade. For that reason we later upgraded to a Fuji F700. The Fuji is fast everywhere the Ricoh is slow. The dynamic range is better (still miss the latitude of film) and movies are much more tolerable. We shoot a lot of video but with a max time of 7 minutes per card it is a big limitation. However, it fits comfotably in my wife's purse and so it meets the size and availability criteria.
Now to the HD1. This would be my wife's primary camera. I don't care that it isn't as good as a larger $1400 Sony. I don't even care that there might be noise form the zoom. I can't focus or zoom the Fuji at all once I start taking a movie clip. So here are my questions:
1) How does the feel and apparant size compare to a typical compact camera like the F700 (not the ultra compacts)?
2) How well does it focus in low light? The Ricoh was horrible. The Fuji is great with its focus assist light.
2b)Heck, how does it focus in general? We missed shots on the Ricoh due to slow/poor focusing. The Fuji is fast and accurate.
3) As a still camera, can it replace my Fuji?
4) How is battery life if only taking stills? Most video we shoot is short and we shoot more stills than video.
5) How is the dynamic range if that is the correct term? I am thinking the photo equivalent of the density rating for a scanner. The Fuji is much better than the Ricoh. Shadow detail? Sky gradations?
6) How is it in low light as a still camera?
7) How is it in low light on video? I suspect it is much better than the Fuji which is poor.
8) Is handling as easy and natural as it looks?
Most posts here have talked about making movies or viewed the HD1 as a move down from a camcorder. No great epic at the Platt's house - just family video. How is the HD1 as a step up from the Fuji F700? Is the HD1 a good pocket camera or is the grain a lot worse and make it unsuitable.
Thanks for putting up with my long winded post.
Paul
Paul Platt is offline
Old February 16th, 2006, 08:02 PM   #175
Paul, not having any of the cameras you speak of, or even a compact camera any time recently, I can't answer your questions very well. But I will try since I have the HD1 ;)
> It feels very small. I could not imagine using anything smaller. It feels like holding a deck of cards, but a little bigger.
> I think auto focus is a little slow in general, and even worse in low light.
> Even holding the camera still, a few still shots have been blurred. You want to hold down the button half way to left it focus take effect before taking the shot. Of course I would get many blured pics from my Sony f828 also. Maybe it's just me ;)
> Stills are very good in good light. Low light shots have a lot of grain.
> Have not used it in that regard, but I imagine you would get better battery life then from video. The battery is rated at an hour, but you never get that. Spare battery is very small and inexpensive.
> The range seems pretty good for stills. In video much less so.
> Have not tried very low light. Some of my stills posted are in pretty low light. I think there is one called trash.JPG.
> Pretty noisy. trash.MP4 is pretty low light. lowlight.MP4 is very low light.
> It is hard to hold still as it is so small. Once you have the LCD open it is easy to control with one hand.
Old February 16th, 2006, 08:11 PM   #176
BTW, I have been to Duluth a few times. Like that Discover mall.
Old February 16th, 2006, 08:17 PM   #177
One other thing is that you really need the LCD to get a good framing. If you hold the camera straight it is actually pointing upward a good degree. In the sun the LCD is very hard to see.
Old February 16th, 2006, 08:24 PM   #178
Tom, so on your 50 incher did the picture look better then what you would get from a good SD camcorder? Or a SD TV broadcast?
Old February 16th, 2006, 09:03 PM   #179
Joseph,
Thanks for the detailed reply. I think someone can win with a great compact consumer camera that does usable (quality and recording time) video or an excellent video camera that is ok for stills. I worry if the HD1 is compromised into being mediocre at both. The HD1 video quality is better than the Fuji. The C6 certainly takes much better low light video than the Fuji based on the clips I have seen. The Fuji and Ricoh would be worthless in a dark nightclub. Your comments on low light grain in the stills concerns me a little. I'll have to compare your stills to some I have take on the Fuji. The focusing issues concern me more. My kids are 5 and 9 so movement is something we deal with. The C5 has a nice form factor. Sherri and I saw it at Sharper Image. I was worried the HD1 was a lot larger.
Does noise reduction help at all?
Not a lot of people know Duluth, GA. It's particularly fun when we go to Duluth, MN and people ask where we are from.
Paul
Old February 16th, 2006, 09:16 PM   #180
Jeez, you'd think that a writer in the Times technology section would know the difference between HDTV and HDV. He consistently refers to the HD1 (as well as the Sony HC1) as "HDTV" camcorders.
Good luck.
Dennis
Dennis Vogel is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
