Head option for a monopod at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
Old June 11th, 2005, 09:39 PM   #1
I just bought a Bogen 503 head, and it comes with a quick release plate, and I have it installed on my PD170. Works perfect!
But, I want to get a monopod now in addition to my tripod, but I'm not sure what to do about the quick-release plate. If I get a monopod without a head, the I have to remove the plate to secure the camera to the monopod. If I get a head that doesn't use the 503 qr plate, I still have to remove the 503 plate and install the monopod head plate, and vise-versa to mount back on the tripod. Both options sound like a hassle.
What are my options? Should I just remove the qr plate and secure the camera to the monopod? Or is there and option where the same qr plate will work for both the 503 and a reasonably small head for a monopod? The 503 qr plate seems so large.
Dan
Dan Shallenberger is offline   Reply With Quote
Old June 13th, 2005, 08:32 AM   #2
Hi Dan,
I believe what you are looking for is this.
http://www.bhphotovideo.com/bnh/cont...=241139&is=REG
It a Bogen 577 Quick Release Adapter Assembly for about $50. I guess you could look on ebay for a better deal.
These quick release adapters are the way to go. I have them on my monpod and glidecam. It makes it so easy to go from your tripod to monopod to glidecam in just seconds.
Mark Von Lanken
www.VonWeddingFilms.com
Mark Von Lanken is offline   Reply With Quote
Old June 13th, 2005, 09:21 AM   #3
Thanks Mark! That's exactly what I was looking for.
The $50 price tag seems steep, but the convenience is worth it. I will check eBay though... every once in a while a good is found there.
Dan
Old June 13th, 2005, 09:23 PM   #4
The downside of not haveiong a swivel (tilt) on your monopod is it may be harder to control, and also harder to do those cool overhead shots that Mark does. Mark, don't you have a regular 501 head on your mono?
You are either growing or dying.
Bob Costa is offline   Reply With Quote
Old June 13th, 2005, 10:08 PM   #5
Hi Bob,
You bring out a good point.
I have a 3063 head on the tripod in the Moving Camera Techniques DVD. On many of the moves you don't need a head on your tripod, but for the most dramatic, and "boom simulating" shots I do angle the head down.
Dan mentioned that he uses a 503, but he could certainly use a 501 on the monopod. If I remember correctly the 501 is about $100 cheaper than a 503, but about $100 more than a simple quick release mechanism.
Mark Von Lanken
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
