Bogen Monopod Question at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
Old March 28th, 2008, 09:00 PM   #1
http://www.4videoequipment.com/video...d+Head+Monopod
I want to mount my bogen 503 head on top of that then my xha1 on top of the 503, is this practical?
i'm wanting to do this for the sake of overhead shots.
Julian Shapiro is offline   Reply With Quote
Old March 28th, 2008, 10:18 PM   #2
Not practical. I have a simple monopod I like for certain uses. I took it to Europe when space was tight. For overhead shots, use a jib or long legs. I have an old set of Bogen legs that extends to over 7 feet for overhead shots.
After years of lurking, I finally made the mistake of opening my mouth.
Doug Lange is offline   Reply With Quote
Old March 28th, 2008, 10:53 PM   #3
Monopod Suggestion
Julian,
Yes it is possible. I have a 560 Monopod and just took the head off, added a 1/4-3/8 adapter and then attached the 503 head. Works great!
Jon Schwartz
Jonathan Schwartz is offline   Reply With Quote
Old March 28th, 2008, 11:21 PM   #4
Originally Posted by Jonathan Schwartz View Post
Julian,
Jon Schwartz
Thanks, Jon!!
May I ask where you purchased that 1/4-3/8 adapter, or if you happen to know the model/manufacturer of the piece?
Thanks again.
Old March 29th, 2008, 12:21 AM   #5
Adapter
Julian,
Just called B&H Photo and they have it in stock.
Here is the link
http://www.bhphotovideo.com/c/produc...8_Adapter.html
Jon Schwartz
edit: Make sure to carry a small pair of pliers with you as this adapter tends to get stuck.
Old March 29th, 2008, 12:37 AM   #6
Thanks a bunch, Jonathan.
Old March 29th, 2008, 05:03 AM   #7
FWIW: Many Bogen/Manfrotto monopods have dual 1/4” - 3/8” camera fixing screw. You might not need an adapter. See:
http://www.manfrotto.com/Jahia/site/...once/pid/13786
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
