Monopod Head at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
Old February 18th, 2008, 06:10 PM   #1
Monopod Head
I have used a simple Manfrotto monopod without a head with my VX2000 for wedding work and I am now in the market for a new monopod, and/or a head.
My only issue with my current setup is that with the camera attached directly to the monopod, I often find myself awkwardly leaning forward or backward to accomodate tilting the camera on the rigid monopod. I would like a simple, single axis joint that would allow tilting.
Any recommendations?
Rick Newsom is offline   Reply With Quote
Old February 18th, 2008, 07:09 PM   #2
Images: 18
Hi Rick..............
Not that I need it often, but if I need a similar setup to that you describe, I simply screw the pretty cheap pan/ tilt head off my cheap Velbon stills tripod and screw it straight onto the monopod.
Works a treat.
If you don't happen to have something like that hanging about, check out the Manfrotto web site for their single/ double axis stills heads and gizmos.
Also check out B&H's stills support/ heads section for hopefully a better range as well.
CS
Old February 18th, 2008, 07:10 PM   #3
Hi Rick,
I made up my own articulating head a few yrs back.
Harold
Harold Schreiber is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
