Report on the Yi 4K+ - Page 7 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old February 13th, 2018, 08:48 PM   #91
Nightime Test Video in 4K
Shot in "4K HD" mode (4000 x 3008 = 4K+!) and rendered at 3840 x 2160 (UHD).
Mark Rosenzweig is offline   Reply With Quote
Old February 18th, 2018, 10:26 AM   #92
Re: Report on the Yi 4K+
Slow motion, 4K, and night:
From 4K60P. Neat video was used to reduce noise.
Old February 26th, 2018, 10:05 AM   #93
Old February 28th, 2018, 10:44 AM   #94
Mark, what's the difference between the 4K+ and the 4K? An extra hundred bucks, and I can't tell a difference in specs or build.
https://smile.amazon.com/YI-Sports-A...dp/B01CW4AZ4M/
https://smile.amazon.com/YI-Action-S...dp/B01FU9ZIMU/
Mike Watson is offline   Reply With Quote
Old February 28th, 2018, 04:02 PM   #95
The Yi 4K+ has 4K 60P, the Yi 4K only goes up to 4K 30P. Faster frame rate, smoother action.
The Yi 4K+ provides electronic image stabilization in 4K (30P), the Yi 4K does not have stabilization in 4K
You can shoot raw images in the 4K+.
Live streaming in the Yi 4K+ in HD.
Because the Yi 4K+ has a more powerful processor, performance is better in all dimensions - video noise, for example, and faster transfer speeds via usb.
Old March 8th, 2018, 10:30 AM   #96
Snow Storm Video
Old March 8th, 2018, 12:49 PM   #97
Mark,
Is there a way to run the camera from AC or an external power pack for extended time lapse work?
Special cable, etc?
Thanks.
Ken
Ken Plotin is offline   Reply With Quote
Old March 8th, 2018, 03:40 PM   #98
Originally Posted by Ken Plotin View Post
Mark,
Special cable, etc?
Thanks.
Ken
Absolutely - normal USB-C cable to normal USB 5V AC adaptor, min 1.5 amps, or to external USB 5V 1.5A battery pack. You can run the camera this way indefinitely, even without a battery installed.
Old March 10th, 2018, 11:42 AM   #99
Thanks Mark.
I only need to run the camera in time lapse mode for a week at a time, so that should work. Power banks are pretty cheap now.
Ken
Old March 18th, 2018, 02:54 PM   #100
What are you using as a lens cap for your YI cameras? I found a lens cap/case that's in the $15 range but I have no interest in the case and $15 seems spendy for a silicone lens cap the size of my fingertip.
I find the fisheye lenses on these action cameras get beat up easily because they're convex and they protrude, so I prefer to keep them covered.
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
