#31 | |
Re: Report on the Yi 4K+
No stage stuff yet - the camera does need a lot of light. |
#32 |
Have you defished the footage or is it unaltered?
Most cameras do well in daylight so it will be interesting to see some spotlit stuff |
#33 | |
There is a spot meter mode, which will be very useful for spotlit scenes! |
#34 |
Joggers in slow motion in 4K
#35 |
24p, 2:39 aspect ratio, shot flat color and color graded. |
#36 |
I'm wondering if the Yi 4K +1 will employ the DSCRX0 1" sensor?
Have you any indoor footage to show? please and thank you :) |
#37 | |
#38 |
Is there any control over the audio level or is it AGC like the GoPros?
#39 |
thanks, that was illuminating :)
not to shabby at all and quite natural. I could get 2 of these for the price or a RX0 |
#40 | |
The Yi 4K+ allows setting two levels for audio, low and high. High is the "natural" setting. The dynamic range is large, with no pumping. 'Low' is for rock concerts, where the levels are very loud and constant. At 2:34 in this video, a train passes by. You can hear the incredible dynamic range - from soft to very loud to soft again. That can only happen without aggressive AGC. I can see it on the audio waveform. If you listen to some of the above posted videos with ambient sound, you will also hear large differences in amplitude depending on closeness to subject and subject levels. |
#41 |
Thanks Mark.
I had to ask, we went for a ride on a road "train", a diesel powered mock steam locomotive with a few seated cars behind. I only had the GoPro (Hero 4 Silver) handy, so I used it with the stereo Igomic, which gives better quality audio at a lower level than the cheapies, but as we passed buildings the sound level was pumping like mad. Editing is going to be fun! I am impressed with both the video and audio from your Yi 4K+, so now I need to decide whether to replace the Hero or do without as I did before. |
#42 |
I bought the Yi 4K camera a couple of weeks ago rather than the 4K+ version as I didn't need the extras and the general technical spec was pretty much identical. I am generally pleased with the overall performance of the camera compared with my GoPros and SJ4000s with one exception. Neither my 4K LG tv or my editing system Magix Media Edit Pro 7 will play any of the files from the camera. Magix will normally play absolutely anything and I frequently mix 4K footage from my Panny cams with HD footage. With footage from the Yi, Magix just locks up, although Windows media player will play it. The LG tv comes up with a message that says 'unplayable Format'.
Although the files show as MP4, I don't understand why they are not recognised by Magix or the LG. Has anyone else had this problem with the Yi or can suggest a solution? Something else I have noticed is that in moderate low light, there is quite heavy graininess/artefacts on any movement. of the subject or the camera. Mark's low light test video is on a totally stationary subject so doesn't show it. It seems to be a common problem with all the action cams, but I expected a bit more from the Sony chip and a 4K spec. Roger Last edited by Roger Gunkel; September 22nd, 2017 at 05:09 AM. Reason: typing |
#43 | |
#44 | |
Roger |
#45 |
On the Zhiyun Evolution gimbal. |
