Report on the Yi 4K+ - Page 2 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old August 27th, 2017, 12:25 PM   #16
Re: Report on the Yi 4K+
It does do 25p/50p. Same with 4k and others as well (EU model). Just change the video system settings from NTSC to PAL.
Bryan Quarrie is offline   Reply With Quote
Old August 27th, 2017, 12:40 PM   #17
OK, cheers! I couldn't find that info, so assumed it didn't.
Dave Baker is offline   Reply With Quote
Old August 27th, 2017, 03:22 PM   #18
Here are the specs:
https://www.yitechnology.com/actioncamera/specs/id/11
Mark Rosenzweig is offline   Reply With Quote
Old August 27th, 2017, 06:57 PM   #19
Yi 4K+ and Zhiyun Evolution Gimbal: Sound Test in Washington Square in 4K 60p
YouTube streamed in 4K60p:
Vimeo version streamed in 4K 30p, but the original 4K 60p video is downloadable:
Sounds from a saxophone, fountains, construction equipment, guitar.
Old August 28th, 2017, 01:48 AM   #20
It looks to be quite an improvement on the GoPros, slightly cheaper here too!
Out of interest Mark, how did you capture the audio, internal mikes, external mike or separate recorder? I ask because it sounds pretty clean to me.
I begin to wonder if there is any great need for any other camcorder for general use!:-)
Old August 28th, 2017, 09:56 AM   #21
When one uses a lightweight gimbal dedicated to action cams the internal mic ends up right against a motor. So an external mic is necessary. I used the Sony ECM-CS3, clipped to the gimbal.
At the end of this short video I show the "rig" - camera, gimbal and mic.
Old September 1st, 2017, 08:59 AM   #22
Yi 4K+ on a the Zhiyun Evolution gimbal at the end of the day. Can be viewed in 4K 60p.
Old September 5th, 2017, 09:59 AM   #23
On gimbal and with external mic
Old September 5th, 2017, 12:02 PM   #24
Mark, I thought that camera could not accommodate an external mic.
Dan Gunn is offline   Reply With Quote
Old September 5th, 2017, 12:18 PM   #25
This is the Yi 4K+. It supports an external mic through the usb-c port (same as the GoPro 5). Yi sells a cheap adaptor - analog port to usb-c.
One must use an external mic when the camera is mounted on most gimbals, because the internal mics are so close to the gimbal motors, and the motor noise is recorded. As you hear in the videos above, there is zero gimbal noise. I use the tiny Sony ECM-CS3 mic, attached with its clip to the gimbal bracket (not the handle, so there is no handling noise and no motor noise).
The rig is pictured at the end of this short video:
Old September 10th, 2017, 07:22 AM   #26
Note the dynamic range of the audio at the end, when the real train (Amtrak Acela Express) comes.
Old September 10th, 2017, 09:36 AM   #27
Mark, got any suggestions on the batteries and cards? My intent is to set up a pair of these to cover me when I am moving.
Old September 10th, 2017, 09:54 AM   #28
These batteries work fine, and you get a charger that works well too (I have this set):
https://www.amazon.com/Newmowa-Repla...QYYWZTSY2QHKG8
Yi has a list of microsd cards that work on their web site:
https://www.yitechnology.com/yi-4k-p...n-camera-specs
Old September 11th, 2017, 12:03 PM   #29
Old September 11th, 2017, 02:27 PM   #30
fantastic watching on a 4k 27" hp envy monitor and it's quite lovely.
Any focusing or is the depth of field everything out there?
Have you shot any stage stuff with it?
Bruce Dempsey is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
