HDR-AS100V POV Action Cam - card information needed - Page 2 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old May 18th, 2014, 02:56 PM   #16
Images: 2
Re: HDR-AS100V POV Action Cam - card information needed
Good point Ron. Certainly in my case with the Kingston I just popped it in and away we went (after I turned it around the right way).
John McCully is offline   Reply With Quote
Old May 18th, 2014, 08:58 PM   #17
Originally Posted by Ron Evans View Post
Did you format the cards in the camera ?
Yes, I formatted in camera before and after formatting to exFAT on the computer. Formatting in camera didn't change the card format to exFAT so that's why I did it on a computer (OSX if you're wondering). According to B&H XAVC-S recording requires SDXC cards, so that's what I'll try next.
Originally Posted by John McCully View Post
Matt, I am quite surprised that the Sony 32GB microSDHC Class 10 UHS-1 Memory Card with microSD Adapter didn't work. The card that did work for me is also a class 10 UHS-1 I believe but is 64 GB.
Do you have a link to the card that worked for you?
Matt Sharp is offline   Reply With Quote
Old May 18th, 2014, 10:39 PM   #18
Images: 2
Better than that: here's a photocopy of the container the card came in.
Old May 19th, 2014, 01:15 AM   #19
Did you format the cards in the camera ? I know I had to do this for the GoPro even though I had formatted to exFAT in the PC.
Ron Evans
The GoPro formats it's own little modified exFat version to the card, that's why a computer exFat format will not work correctly and why you should not then cross use it in other devices.
Ian Newland is offline   Reply With Quote
Old May 19th, 2014, 05:31 AM   #20
Yes I know, that is why I wondered if the Sony needed to format in camera when set to XAVC-S too. It is always good to let the cameras format as they often place directories during the format for data base recovery etc.
Ron Evans
Ron Evans is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
