GoPro and DP6 field monitor. at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old March 29th, 2014, 05:50 AM   #1
My GoPro 3+ black works well with a DP6, should a GoPro 2 work also?
Old April 3rd, 2014, 10:00 AM   #2
Re: GoPro and DP6 field monitor.
I use a DP6 with the GoPro2. you have to use the HDMI cable (I can't get the TV jack to work at all) and usually i have to connect the two, turn on the DP6, and THEN turn on the GoPro2, or the monitor doesn't recognize the signal. YMMV.
Bill Ward is offline   Reply With Quote
Old April 3rd, 2014, 06:25 PM   #3
Thanks Bill, that works.
Alastair Traill is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
