Upgrading to Hero 3 Black at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old March 5th, 2013, 06:39 AM   #1
Guys,
I currently have a Hero 2 and am considering the upgrade to HD3 Black for a number of reasons but Im reading so many bad reviews about locking up and the WiFi packing in.
Are they really this bad and should I trade up or stay put for now until things are sorted?
Alan
Alan Maughan is offline   Reply With Quote
Old March 7th, 2013, 05:05 AM   #2
Re: Upgrading to Hero 3 Black
144 views and nobody has an opinion?
Old March 7th, 2013, 06:18 AM   #3
only had my black for a couple of days. No freezes or crashes so far. Out of the box I went to the website to download any software updates but it said it was already on the latest version. I haven't used protune yet. The wifi seems ok, chews the battery though.
Damian Heffernan is offline   Reply With Quote
Old March 7th, 2013, 09:47 AM   #4
I've exchanged 2 already. Number 3 is going back for exchange from the factory. They've all worked, but the freezing problem is widespread.
Old March 7th, 2013, 10:58 AM   #5
I got one last week, used a couple of times, it froze when it was plugged to the computer while charging. I had to take the battery off, then it worked. Haven't used much yet since then.
Erick Munari is offline   Reply With Quote
Old March 8th, 2013, 02:30 AM   #6
I cant say the comments so far have inspired me to make a purchase - how can GoPro get things so wrong and not resolve these issues quickly????
Crazy.
Old March 8th, 2013, 03:43 AM   #7
I bought one the other week. So far so good. Took it out on the boat yesterday to do some test shots and it worked just fine.
Battery life is a bit weird. I was able to get it to run continuously for 4.5 hours with a second battery. But now I'm just getting 2.5 hours. Same batteries. No extensive charge cycles.
I know WiFi can shorten battery life. But the endurance tests were conducted with WiFi turned off.
Dean Sensui
Old March 9th, 2013, 12:23 PM   #8
I have two Blacks and use them with protune and 2,7 K.
Used them on three jobs and didn't fail so far.
I used them both with RC remote and Iphone app.
I use them with the additional battery. I never charge from computer.
Charging the additional battery attached to the camera doesn't work I have to charge it separately.
The three jobs where on car races and winter olympic sports.
Eugen Oprina is offline   Reply With Quote
Old April 16th, 2013, 05:39 AM   #9
Originally Posted by Dean Sensui View Post
...Battery life is a bit weird. I was able to get it to run continuously for 4.5 hours with a second battery. But now I'm just getting 2.5 hours. Same batteries. No extensive charge cycles....
I see the battery pack is getting thrashed on the GoPro website reviews. I realize the freezing was firmware but has the battery life settled down? I would think the battery pac easier to make fast battery changes. You OK with just swapping batteries?
Old April 25th, 2013, 02:27 PM   #10
I've had my Hero 3 for two days and its locked up twice. Had to remove the battery both times to fix it. I updated the firmware today. Hopefully, no more lock ups.
Michael Sims is offline   Reply With Quote
Old April 25th, 2013, 08:42 PM   #11
I haven't had a single lock up since updating the software. Only done a couple of hours with it since updating but so far so good.
Bryce
Old April 25th, 2013, 09:25 PM   #12
I have 2 Blacks, 2 HD2 and HD1 - I only mention this because I use all three and there are differences. However - sticking to the question, I have only had one lockup issue in a month. Battery life sucks, but what I learned is that the Backpacks that I have for the HD & HD2 work on the 3 as well as the LCD.
I use the Battery BackPac when I am using the WiFi and I have yet to run out of battery during a shoot.
The only real issue I have is with Adobe CS6 - when I am shooting 120fps - adobe only recognizes 60fps - so the audio is twice as fast. If audio is nit needed - then your good.
Most everything I shoot is action sports - so I have not experienced with the higher resolutions yet.
Chris Sgaraglino
The Outdoor Life Blog | Widow Creek Photography
Chris Sgaraglino is offline   Reply With Quote
Old April 26th, 2013, 06:51 AM   #13
I had a mystery lock up the other day when getting data off and charging. I'm pretty sure though I have damaged mine with excessive heating due to filming in a glass studio. I cannot afford a camera that I can use different lenses with so getting up close and personal to a subject that is radiating hundreds of degrees of heat probably is not doing it any favors. I film at 2k@30fps
My theory about the freezing is excessive heat build up. My camera will shut off when after filming glass blowing. I put it in a freezer for about 10mins and it starts back up again.
I had no problems with the camera locking up while it was mounted to my canoe this past winter filming numerous whitewater runs. Just battery life issues that seem better in the glass studio.
My perception is that the small form factor makes the gopro3 excessively vulnerable to huge temperature issues.
Soon I am going to modify a water proof case to let me connect a solar panel to it. I am going to do a timelapse until the memory card is filled or the camera shuts off. I imagine it will freeze because of the higher late spring temperatures.
John Forsythe is offline   Reply With Quote
Old April 26th, 2013, 10:05 AM   #14
Have you tried right clicking on the clip in the project panel, click on modify, then interpret footage and then where it says assume frame rate, change the frame rate to 120. I've never tried it, just an idea.
Rob Morse is offline   Reply With Quote
Old April 26th, 2013, 10:07 AM   #15
I've only used my Hero 3 on 2 projects but had no issues at all.
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
