Sneak Peek at Sony POV - Page 7 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old September 29th, 2012, 12:53 PM   #91
Shooting with the AS15 at high bitrates
The Sony HDR AS15 puts out a clean HDMI signal including the sound from the microphone, which means you can record externally. I recorded with the Atomos Ninja2 using *144Mbps* Pro Res. The camera was recording at its native MP4 at *16Mbps*. Both recorded at 108030p. The uploaded file that contains both types of recordings (two scenes) is MP4 108030p at bitrate 26Mbps (combined in Vegas Pro). Thus you can see if there is a quality change if the bitrate were higher than what the camera uses. The internally recorded clip precedes the (original) Pro Res clip for each scene. See any difference?
Sony HDR AS15 Test Video: Comparison of Native 16Mbps Files with 144Mbps Pro Res Files - YouTube
Mark Rosenzweig is offline   Reply With Quote
Old September 30th, 2012, 03:51 PM   #92
Re: Sneak Peek at Sony POV
Tested it out today on my car. Does not like heat. Was around 95 here and it keep shutting off. Sony needs a more open case for it.
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old September 30th, 2012, 04:02 PM   #93
I wondered about the heat/sun factor. Maybe just painting it white would be an improvement?
Lynne Whelden is offline   Reply With Quote
Old September 30th, 2012, 04:30 PM   #94
Anyone know what the range is for the wifi?
http://www.markoconnell.org
Mark OConnell is offline   Reply With Quote
Old September 30th, 2012, 05:36 PM   #95
I walked away about 15 feet and it worked. Also worked inside the car when mounted on the back.
Old September 30th, 2012, 05:37 PM   #96
I might buy another case on drill it out.
Old September 30th, 2012, 09:54 PM   #97
Thanks Duane.
Old September 30th, 2012, 09:56 PM   #98
I used it at 50 feet yesterday.
Yes, the case is a problem and fogging is a problem and I had fits playing with the slo mo mode. It is not a P&S camera IMO.
It also has a lot of potential I think.
Don Litten is offline   Reply With Quote
Old September 30th, 2012, 10:36 PM   #99
That is one thing I like about my Contour, the rotating lens and mount makes it really easy to find a good position and no need for a case.
Old October 1st, 2012, 09:17 AM   #100
I haven't had an issue with fogging yet. I also haven't had heat shut it down yet but I did notice enough heat while shooting some time lapse's that I built a mount that let it be exposed for that.
DIY Open Mount for Sony HDR-AS15 Action Camera - YouTube
So far I've been a little over 20 yards from mine and still been able to run it with the phone but then I've also had interference at less than 5 feet from my blu-tooth ear piece.
Woody Sanford is offline   Reply With Quote
Old October 1st, 2012, 11:08 AM   #101
Some slow motion tests.
Mounted on my car
My friend also did some with his
Old October 3rd, 2012, 10:38 PM   #102
Thanks a lot for those videos Duane. Those sort of shots are what I want one for.
I just had a look at the Action Cam at my local Sony Store and it looks pretty nice but it is a little disappointing that you always need the case! I will definitely be giving my drill a workout if I get one.
SONY α77 :: Panasonic X900M :: Sony DSR-PD170P :: Miller DS5 :: Premiere Pro 2.0 :: Cineform NeoScene
Laurence Janus is offline   Reply With Quote
Old October 4th, 2012, 06:49 AM   #103
Look at Woody's posts Laurence. He came up with a cheap and very usable (I made one) out of case mount.
My only concern about using it out of the case is that on many POV lenses (Especially GoPro) the coating on the lens is extremely soft and easily damaged.
They just don't go to the extra expense of using hard coatings because it's supposed to be used in the case.
Old October 4th, 2012, 11:10 AM   #104
Thanks for mentioning that. I did not consider that. I have been using it in the DIY mount quite a bit. I shot another cloud time lapse yesterday and let it run for an hour. Man, it got hot. It didn't shut down but I could not make a fist around it. It was as hot as coffee out of the pot. I shot using the DIY open mount and am glad I didn't try it in the full housing. I would NOT recommend shooting an hour long time lapse in the full housing.
I had originally thought that the heat issue was something internal that would just cause a card not to write or something small like that but this thing can get crazy hot.
cloud time lapse shot for an hour on Sony HDR-AS15 - YouTube
Old October 4th, 2012, 11:53 AM   #105
How do you charge the battery in the camera ?
Brent Kaplan is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
