Thread Tools
Search this Thread
#121 |
Re: GoPro Protune
Just a heads up, take note of what Abe said above, not only does it explain well what ProTune is but as GoPros Head Editor you got it straight from the "'horses mouth"
Thanks for the explanation Abe. |
#122 |
Re: GoPro Protune
Ok Chris,
Just to throw a little more confusion to the equation. I just changed the format to pal & i still have the same amount of time showing; 2h 58min.??? I don't get it. I have tried formatting the card, but that doesn't seem to change anything either. I have just turned protune off & in 1080-30p it is showing 4h 45min. I will try recording a clip & time it, & see what the time remaining counts down to & let you know. Bryce
There's never enough hours in the day! |
#123 |
Re: GoPro Protune
Ok, so i just checked again, & sure enough, the time remaining goes down equal to the length of the clip as it records. I also just checked the settings & recorded two clips, one without protune on, & with with it on. The one without is recorded at 14999kbps & the one with protune turned on is recorded at 35110kbps according to Gspot.
I can't understand why your recording time is so short for a 32gb card. Bryce
#124 |
Re: GoPro Protune
Hi Bryce
I found out what the issue is!! It's the frame rate!! At 1080 25T on a 16GB card I have 41 mins ..if I change the mode to 1080 30T (still in PAL) I now get 1hr29mins which would be the same as your 2hr 58mins on a 32GB card. I wonder why a 25T frame rate needs so much more space??? If you set yours to 25T you will also see the time effectively cut in half!!! Just for interest if you set to 24T you get 1hr 10mins which is still better than the 25t mode. Anyone else know why the 25T mode eats up so much card space??? What are the PAL guys shooting in?? Chris |
#125 |
Re: GoPro Protune
Ok this is getting weird now!!
I set my cam to 1080 30T and it automatically set itself to NTSC not PAL...so I went into the menu again and changed NTSC back to PAL and voila..it changed the frame rate from 1080 30T to 1080 25T and I now have 1hr 29mins on a 16GB card. All I can think is that the camera might have switched back to NTSC and by setting a 25P mode it needs lots of space to do the 30t to 25t conversion. It's definately now on PAL and 1080 25T and has the correct amount of space...so it seems if you play around with modes you MUST go back and check everything else too to make sure they are still set correctly...also when you change frame video mode it also seems to reset FOV too!! However it kept ProTune on!! Chris |
#126 |
Ruler of the DownUnder UnderWorld
Re: GoPro Protune
Editing the raw ProTune files in EDIUS with CC is a piece of cake here.
I find as the H.264 compression in DSLR's cannot handle solid tones to set the colour in the camera before you shoot. Do it later and you enjoy all the compression banding. Converting to another codec is a waste of time too as the compression banding is there in the raw footage to start with. Just a limitation with H.264. As one cannot set the color on the little GoPro's then you have no choice but to shoot flat. I converted the Pro Tune to Canopus HQ fine avi and there is no difference in quality when adding in the same CC just makes mega huge files.... so just edit the raw ProTune files if your NLE can. |
#127 | |
Re: GoPro Protune
#128 |
Re: GoPro Protune
Hi Abe
I'm simply looking at the time on the front display... I'll go thru the settings again and double check everything. Now on my Panasonic cameras, at 24mbps I get 97mins on a 16GB card so to me 1hr29 sounds totally off if it's recording at 35 mbps the 41 min figure sounds a lot more accurate. The display could quite rightly be highly inaccurate!! I'll give it an 40 min run in the morning here at a wedding I'm doing and see if the actual record time and display get better Thanks for the help Chris |
#129 |
Re: GoPro Protune
I tinkered with mine in Premiere last night – my first ever attempt to do anything besides apply ‘auto color’ in post for ‘color correction.’ I’ve got no idea what I’m doing; used ProcAmp and Equalize after toying around with some other controls and finally got something out that doesn’t look too horrible to me. I’ve actually been keen to try tweaking on adjusting some video in post processing anyway.
Mine is coming back for a 2:37 minute clip to encode in 8:30ish minutes; which is probably a bit more than usual. I’m usually about double real-time on an i7 quadcore 3.4 ghz/cuda video card machine. At any rate, it’s all working for me or seemingly so – just FYI. |
#130 |
Re: GoPro Protune
I have applied the update but now find that my SanDisk class 4 15MB/s SD is not fast enough for the Protune capture speed. I get only a few seconds captured before I get a warning that the footage could not be captured as my card is too slow.
What speed card is the minimum to record the Protune version? |
#131 |
Re: GoPro Protune
When is the App for Android coming???
#132 |
Re: GoPro Protune
#133 |
Re: GoPro Protune
Maybe my brain is a little fuzzy this morning but if it records at 35mbps would it matter what frame rate it records. Shouldn't the time be the same for all of them?
Gordon |
#134 |
Re: GoPro Protune
#135 | |
Re: GoPro Protune
