Thread Tools
Search this Thread
I'm looking for a....smaller camera
So much like the ice skater, I play hockey. However I'm the Goalie, and I'm looking for a video camera to fit inside my helmet.
I've looked at the Replay, and the standard version may be JUST a little bit too big. I'm curious if there is anything smaller? I also looked at the Looxsie or whatever, and that may be able to fit, but I BELIEVE that requires a phone to be by you. Which I could probably do, just prefer not altering my equipment to do so. Any help would be greatly appreciated. |
Re: I'm looking for a....smaller camera
if you split camera from recorder, you can find very small camera (less than sugar cube sized).
then you can wire a solid state recorder somewhere else. or you can use these ones |
I got one of these for use by a skater in capturing ice skating. It has a separate camera from the recorder and uses a cable to connect. You can stop, start and mark video with an included remote control.
VIO POV HD DIGITAL HELMET CAMERA SYSTEM $599 POV.HD Digital Video Camera :: V.I.O. |
I am looking for a smaller camera too,
but I need the best possible 1080 image under 1lb, I am getting into aerial video and no crazy investments into the aircrafts, but it doesn't apply to camera, so my budget is open, currently I am choosing between s9100 and gf3, any help is greatly appreciated!
I love this place! |
#5 | |
#6 |
I don't have it with me but I believe the end is about the diameter of a silver dollar, if you have seen those. I can do a tracing and post it if you like. The issue might be getting a decent shot, with your head being in there too. It certainly isn't a "spy cam" size!
#7 |
I think this is it
NEX5NKB | α NEX-5N with 18-55mm Lens | Sony Canada but with the 16mm2.8 though
#8 | |
#9 |
I talked with the guy in the pro shop at our local rink. He said at an NHL game, he saw a cam mounted outside the helmet because there isn't room inside. If you dig out any foam, it might compromise the helmet integrity. Your brain is more important than a video ... or whatever that saying is.
