Cable Dolly movement with Gopro - anyone at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old May 8th, 2011, 02:28 AM   #1
Hi,
I want to shoot a stream of water from above for around 10 meters , dont need to do it with a DSLR but with a POV like gopro, have a GOpro HD with me.
Has any one tried this and any suggestion.
transporting a gopro on a cable at a steady pace from point 1 to point 2
my object is to have one point at bottom of the stream and one at top of it and try and see if i can make my pov go from down to up.
1) is any product available that can make this possible
2) has anyone done a DIY on this type of situation
Kindly let me know.
Vishal
Vishal Jadhav is offline   Reply With Quote
Old May 8th, 2011, 05:55 AM   #2
Re: Cable Dolly movement with Gopro - anyone
It should work...the trick is going to be to power it. I'm sure that someone makes a power unit, but I wouldn't even begin to know where to look. Since you're shooting with a go pro, my thought would be to go "low tech" with PVC.
say, three T-joints and a couple of feet of PVC..one t-joint slid over two separate cables/ropes running parallel to one another. add a couple of 4in. pieces to either end of the joints for added front to back stability. join the two together with two additional 4in pieces of PVC and another T-joint. Use the T-joint in the middle as your mounting point for the gopro.
Run a third, lightweight line from the mount to your ending point, and then you could manually pull it up the lines. Alternatively, if you want to get "fancy", take an old bicycle, remove the rear tire from the rim, and turn the bike upside down. anchor the end of the rope to the bicycle's rear wheel, then hand turn the pedals and crank the line up onto the bike rim.
Something like that may be a viable option, actually. an old bicycle is easy to find and cheap, the PVC would be more than up to the job of hauling a gopro, and cranking it along with the bike pedals would be fairly smooth.
just thinking off the top of my head, but it seems like it would do the trick
Wayne Reimer is offline   Reply With Quote
Old May 8th, 2011, 07:04 PM   #3
These posts should help you out
GoProUser.freeforums.org • View topic - Cablecam for GoPro HD!!
GoProUser.freeforums.org • View topic - GoPro CableCam
Cheers Rambo
Ian Newland is offline   Reply With Quote
Old May 9th, 2011, 08:00 AM   #4
YouTube - Cablecam Gopro Hero HD Made in Cordoba.
CableCam.org - View topic - The Spanish proyect
Old May 9th, 2011, 08:22 AM   #5
looks like we have a vertical path here.
If so your first problem will be to find something on the top to make your end point.
since you use a go pro, you could check for an helium balloon to gently lift the camera or just lift some light wire.
Old May 9th, 2011, 08:41 AM   #6
Thanks folks
that was really helpful.
Will try and make one of those so that i have the shots i need.
in case anyone has a DIY let me know
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
