Removing 3M GO Pro mounts from car at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old April 14th, 2011, 01:15 PM   #1
I wanted to pass along a little trick I discovered trying to remove a 3M Go Pro mount from the hood of my car.
I mounted two of them on the hood of my 2009 Saturn VUE, about halfway up on the driver's side. I had to use the 3M mounts because I had forgotten my suction cup mount and I was too far from home with a client to go back. So, I ended up using two of the 3M mounts on my car so we could get two different angles while driving the car.
I got home and thought about how I was going to remove those things and I went looking for my can of WD40... well to make a longer story short, I took the can and a small wad of paper towels and shot the WD40 under the 3M pads all around both of them and wiped up the excess.
I waited until the next afternoon to let the WD40 soak in and tugged on them a bit before I took a flat blade screw driver and pushed on the 3M pads between the car's hood and the plastic Go Pro mount and after some little work I was able to twist the 3M pad and the mount attached to it right off without damaging the paint.
I have to admit, I plan to use the suction cup next time, but just in case... you can remove the 3M Go Pro mounts without damaging your car's paint.
Good Luck! My HD Hero Go Pro has been a nice addition to my camera package.
George Wilkins
George Wilkins is offline   Reply With Quote
Old April 14th, 2011, 02:53 PM   #2
Re: Removing 3M GO Pro mounts from car
Another "trick" for removing them is to use a piece of waxed dental floss. If you are careful, you can position it between the adhesive and the surface it's stuck to and using a sawing motion, "cut" through the adhesive and lift it off
Wayne Reimer is offline   Reply With Quote
Old April 15th, 2011, 07:54 AM   #3
wd40?what is it^
thx
Old April 15th, 2011, 09:54 AM   #4
Originally Posted by Marcus Martell View Post
wd40?what is it^
thx
WD-40 - Wikipedia, the free encyclopedia
WD-40 Lubricates, Cleans, Protects, Penetrates & Displaces Moisture
Bill Koehler is offline   Reply With Quote
Old April 15th, 2011, 10:13 AM   #5
You forgot, 'removes GoPro mounts', Bill.
Old April 16th, 2011, 03:28 AM   #6
A thousand and one uses. Now a thousand and two.
-- quoted from the movie "FX".
Dean Sensui
Old April 16th, 2011, 06:45 PM   #7
I've also heard that using a hair dryer to warm the adhesive works well too. I have yet to try this but sure hope that it works... the last mount I removed from my airplane pulled a chunk of paint off, down to bare metal! eeek
Trevor Meeks is offline   Reply With Quote
Old April 17th, 2011, 07:21 AM   #8
a hair dryer or heat gun will work really well. That, and the dental floss trick, is an old motorcycle riders trick for removing adhesive reflectors from front forks, etc.
Being an old motorcycle rider, I've taken off a few reflectors ( and a couple of gopro mounts) that way. It works very well, without having to clean up WD-40 afterward
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
