2.5mm adapter at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old April 11th, 2011, 02:41 PM   #1
2.5mm adapter
The GoPro Hero HD has 2.5mm jacks for outputs.
I want to use my small wireless SD video sender. The supplied 3 way RCA cable is too much of a bundle to use well.
So I need a 2.5mm jack to a single RCA or BNC on a short cable using the video segment of the TRS.
I could also use a 2.5mm to 3.5mm adapter as long as it connects the video portion of the TRS as well.
I can't find anything on the net. Lots of Red/White/Yellow 6' cables which I already have and don't want.
Lots of audio connectors for cell phones which I'm not sure will pick off the video portion of a TRS connector.
Ideas?
Ed Kukla is offline   Reply With Quote
Old April 11th, 2011, 08:57 PM   #2
Re: 2.5mm adapter
I also had the same issue and also wanted 90 degree 2.5mm without using and adapter. I had to cut some from other leads and join them into a short (300mm) cable and cover with heat shrink.
2.5mm AV 4 segment 90 degree ---> 3.5mm AV 4 segment 90 degree
Ian Newland is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
