#46 |
Re: GoPro LCD back now available
Just to update. I contacted GoPro and he went threw some setting and said there is a major problem. I have to send them the LCD and the camera together.RRRRR Any way I really appreciate all the help. By the way I did all the above to try to get it to work but to no prevail.
Dan |
#47 |
Yes there have been some hardware failure reported, some problems have been with the camera/port but without having a BacPac to test, you never knew they existed. But most are just FW user procedure error.
R |
#48 |
Hi Ian,
I'm interested in the screen that you are using with the Gopro. Where can I find more info on this? and where would one purchase this. Cheers |
#49 |
#50 | |
#51 |
Thanks Ian,
Is this the same one as the Eagle Eye that you have pictured on the previous page? Cheers |
#52 |
That's it, it's also a recorder but i don't use that function, only the av in.
The reason i use that one is because of the small size, fantastic screen brightness and it's own internal 1100mhA battery. But can also be powered by USB. Another use i have for the little monitor is on the operator end of a 4meter pole with the Gopro on the other, just like a mini crane with av monitoring. |
#53 |
Thanks mate,
This looks like a great addition to the GoPro. Cheers |
