any experience on using GOPROHD files and Vegas8?
Hi guys, did you try any Goprohd files onto your Vegas8? Wanted to know cause i've just ordered mine and even if i live in PAL land ans hoots 30 or 60 fps i thought it could be a good choice for action-sports shots.
2nd question: i 'm working on an HDV Pal project, would i consider the option to convert this files in Pal version?If so, how?? :) thx a lot for taking time to gimme an help |
#1. Check out Keith Kolbo's tutorial called Using GO-HD files in Sony Vegas Pro 8
#2. I'm an NTSC user, not PAL so I'll let someone else answer that question. |
MIKe always kind to me, thanks a lot btw What's the biggest difference using 30p or 60p videos on a PAL project timeline?
thanks a lot |
It talks about Go files, not the GOPROcameras full HD files.....
Or are the same thing? other q: Quicktime pro should be bought right? Is not a freeware thank you |
#5 |
Ok, just found out there's a bug with Vegas and the other gopro files larger than 2 GB that couldn't be opened on the timeline...
Any ideas how to split a file that big? thx |
#6 | |
If you copy files from one file-system to the other, the system will split the files into 2GB or 4GB chunks (depending on the software). Unfortunately, with video, that will mess up the long GOP info. I suspect this is the problem you have. i.e. not a bug with Vegas but a file system limitation. AFAIAA the only solution to that is using the NTFS file system on your HDD(s). It's for that reason all my external HDDs get re-formatted NTFS also. (They usually come pre-formatted FAT32). |
#7 |
Go here and read every post!
GoProUser.freeforums.org • Index page I'm in PAL land, but using SVP 9c. Atm I don't have a lot of footage from my GoProHD, but have been playing with the proxystream plugin or converting to Cineform Neoscene. I will shortly be buying Neoscene. I post my stuff to Vimeo so the PAL/NTSC problems don't apply From what I understand, the gopro only records upto 2gb segments. It will split these files automaticly while recording |
#8 |
Is this proxystream plugin free?
thx for helping me out |
#9 |
Marcus, yes, the Proxy Stream script is free (along with several other excellent ones on this site).
p.s. instructions are in a readme file that's a part of the zip file that you download. |
