HD Helmet Camera - Page 3 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old January 8th, 2010, 03:54 AM   #31
Originally Posted by Ian Newland View Post
Shawn,
That's right it won't play unless you have the right codec.
Download either VLC or Classic Media player both will play it fine and require less CPU to do so.
MPC - guliverkli | Get guliverkli at SourceForge.net
VLC - VLC media player - Open Source Multimedia Framework and Player
Shawn,
Here is another link for a media player codec pack for windows XP (if you are using windows) Free-Codecs.com : XP Codec Pack 2.5.0 is one of the most complete codec packs
It to has some codecs that will allow you to play your video.
I thought this may also be helpful.
Cheers,
Jon
Jon Wilson is offline   Reply With Quote
Old January 8th, 2010, 12:09 PM   #32
another good media player is splash lite, I just installed it yesterday and it really works well, loads fast, and will play the mp4s out of the gopro camera..
Mirillis - Enjoy High Definition
John Abbey is offline   Reply With Quote
Old January 8th, 2010, 02:59 PM   #33
Thanks, folks.
I'm glad I found this site
Shawn A. Cronin is offline   Reply With Quote
Old January 8th, 2010, 06:15 PM   #34
What would be the best choice to sh'oot inside a fighter jet cockpit?From the image quality i would say gopro.What would u think
Old January 8th, 2010, 07:01 PM   #35
I agree Marcus, amazing quality I think
Old January 8th, 2010, 11:50 PM   #36
Marcus, I have some experience of working with Go Pro footage mounted inside aerobatics aircraft, and I'd say that it works well for in cockpit stuff although you do have to look out for skew.
In a prop plane facing forward, where you can see the prop, the skew will turn the prop into a continuous curve which looks terrible.
In a fighter plane, I'd imagine you'd have less issues - especially shooting back toward the pilot.
Shooting forward outwards you might have more issues with skew under heavy G's, but because generally the wide angle look means lot of distortion anyway, and the subject matter isn't changing in such a way that it's a huge problem, I'd say skew isn't a big issue at all, unless you were looking for accuracy or trying to capture say other planes passing the jet, like a dog fight type situation, in which case the skew will probably be a problem.
Mounting may also be an issue, because if it experiences a lot of shake inside the plane, it what it is on vibrates because of resonance or turbulence or something, then your picture can turn a bit jello like.
For the money they are good value, but limited.
www.afterglow.co.nz
Craig Parkes is offline   Reply With Quote
Old January 9th, 2010, 02:22 PM   #37
Here is a story I shot last week. I used a Contour HD 720p model for the shot looking back at the pilot.
Take to the skies in '20s-style warbird - National - Video - 3 News
at 1min 50sec you can see the image shift, but for such a short shot, cut in with my other two cameras, it is fine. I use these as 'bonus cams' and put them where I want, not worrying about the cameras safety too much. For this plane shot I just gaffer taped it into a hole on the dashboard in about 1min.
The Contour has been good for me, but I am also keen to try the GoPro.
Ben
Ben Ruffell
Ben Ruffell is offline   Reply With Quote
Old January 11th, 2010, 04:13 AM   #38
Hi Ben,
I'm assuming you shot in 720p60 mode, but since New Zealand is PAL, you then needed to convert to 50p or 50i. Was this a simple process? Personally, I find it frustrating that PAL versions of these types of cameras don't exist.
Geo.
Geoffrey Robson is offline   Reply With Quote
Old February 13th, 2010, 04:12 AM   #39
So what's the mount you suggest me to buy to avoid the G's bad surprise?
I was also considering the fact of the PAL-NTSC conversion....
have a good weekwnd guys
Marcus Martell is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
