Anyone suggest a VHS deck? at DVinfo.net
The Long Black Line
Old May 4th, 2003, 11:41 PM   #1
Hi guys. I'll be on the look out for a VHS deck soon and would like to hear people's opinions on what I should get and what things should I look out for?
Is manual audio control necessary?
Is S-VHS necessary? (Most people don't have that anyway so I assume it's not, or is having SVHS in at least a good thing even if going to VHS)
I take it I'd need HiFi at the least?
I'll be using it to dub off footage and videos that I've made for people and want pretty good quality. I won't be doing bulk work so I guess it doesn't have to be an industrial quality one.
Cheers
Aaron
Aaron Koolen is offline   Reply With Quote
Old May 5th, 2003, 12:27 AM   #2
Outer Circle
A lot of people that shoot use a SVHS VCR as a master. Then make VHS copies from that. Regarding which VCR? I don't know. Most of them are built cheap these days. What I do is find and buy old ones that are built like tanks. If they're broken, I get an estimate for repair and then go from there.
Old May 5th, 2003, 01:22 AM   #3
Thanks Frank. I myself was thinking of using DVD as a master and then going from there. Would have thought that was better quality, no? I guess it would be a bit more expensive.
Cheers
Aaron
Old May 5th, 2003, 02:32 AM   #4
Outer Circle
I don't know about that. Although DVD is 480 lines, and SVHS is only 400 lines, I don't know how DVD to VHS footage would compare with SVHS to VHS. Isn't DVD highly compressed? I'll have to let someone else jump in who has more knowledge about this.
