VTR Decisions - Sony versus JVC DV Decks at DVinfo.net
The Long Black Line
Old April 23rd, 2006, 03:42 PM   #1
Submitted this in the editing section but think here might be more appropriate. I'm considering a VTR deck for DV capture and final output to tape and the choices are boiling down to a decision between Sony and JVC at two different price ranges. In the lower range I'm looking at the JVC BR-DV3000U and the Sony DSR-11 while at the upper end I'm looking at the JVC-BR6000U and the Sony DSR-25. Would like to hear some user comments pro and con on each of these options. Primary role will be capture of miniDV camera original into the NLE - Vegas or Premiere Pro - with possibilty of an occasional need to record final prgram back to tape.
In a related issue, the Sonys will both record and playback DVCAM as well as DV while the JVC's playback both DV and DVCAM but only record to DV. In fact, it seems Sony is positioning their recorders as DVCAM units with an added ability to also work with DV, while JVC seems to position theirs as primarily DV with DVCAM playback added. How crucial a factor should this be in the purchase decision? I'm thinking that the times when I'll be recording to the VTR, the resulting tapes would be intended for primarily for corporate clients and secondarily broadcast submission - seems that DVCAM would be a better accepted delivery format than miniDV and the ability to record in that format would be a strong plus. Comments?
Old April 23rd, 2006, 04:11 PM   #2
Capt. Quirk
There was a Sony, DS10 I think, that was also battery powered. Not a real big point, but it would be nice on occasion.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old April 24th, 2006, 07:18 AM   #3
Hi Steve,
I have a DSR-11, I bought it because it was the most cost effective DVCAM deck I could get at the time that could ingest PAL in addition to NTSC. I already had some other sony DVCAM gear so that made my decision easier. Since then I've found I really appreciate it's compact size and very fast tape fast rewinding. It's also great to take along for recording long meetings or training sessions.
The drawbacks that I've found are that it has no ability to generate timecode and has analog output setup at 0 with no ability to switch to 7.5. There are work arounds, but my next deck will have those capabilities built-in.
Best Regards,
Greg
Greg Bartlett is offline   Reply With Quote
Old April 24th, 2006, 08:45 AM   #4
If I had the budget for a DSR-11, I'd spend a few more dollars and get an HDV deck like the new Sony HVR-M15U.
Toogood Studios
Jeff Toogood is offline   Reply With Quote
Old April 25th, 2006, 10:44 AM   #5
I have been thinking about this too (other kit has higher priority). That would give you ingest for 1080i Sony and JVC 720p. Wider options for projects you could do.
George Ellis is offline   Reply With Quote
Old April 25th, 2006, 12:42 PM   #6
Here's another option just released by Sony and my favorite at the moment.
http://bssc.sel.sony.com/Broadcastan...06&p=16&sp=142
The M25U is next on my shopping list. Does all you want AND HDV!!
Cheers
Jeremy
MJ Productions
Never let the need for money outweigh the need for Quality, Friendly and Professional Service
Jeremy Rochefort is offline   Reply With Quote
Old April 29th, 2006, 09:26 AM   #7
Cheers
Jeremy
Just discovered that myself! Had just about decided on a DSR-25 but now I'm gonna wait. Will rent if I need something in the meantime. The M25U looks very promising!
Old April 29th, 2006, 01:01 PM   #8
M10u
Guys,
Sorry about the cross posting, but I need some shopping help and I might do better here: Trying to decide between M10U and the M15U. M10U has a screen and is portable, can be used with an NP-970 battery. M15 is a bigmouth AC only and no monitor. I know what the obvious answers are: My question is would I be better off with the M15 (I playback thru AJA KONA 2) for overall utility value?
Jack Hubbard
Jack D. Hubbard is offline   Reply With Quote
Old April 29th, 2006, 01:10 PM   #9
Transport
Boyd Ostroff tells me the M10U may have the same transport as the Z1, which is more delicate than a bonafide tape deck. It apparently also has a slow rewind time compared to the new decks. Anybody know the answer?
Old April 29th, 2006, 01:17 PM   #10
Capt. Quirk
The M10U has also been discontinued, from the looks of things. It sounds like it just wasn't up to grade, even if it was a great idea.
Old April 29th, 2006, 01:19 PM   #11
M10u
Thanks, Keith. Makes sense.
Jack
Old April 29th, 2006, 01:22 PM   #12
Capt. Quirk
No problem Jack, I had been looking at the 10U myself. And, as I get closer to having the cash to get my gear, it starts showing up as discontinued. That's the way my days go... *sigh*.
Old April 29th, 2006, 04:21 PM   #13
Originally Posted by Jack D. Hubbard
Guys,
Sony had to release a deck when they brought out the FX1 and Z1 otherwise they would have been in the poo. I saw the M10U as an intermediate device and never got one - somehow I had the feeling that a better deck would come. Little did I know what the upside would be. I have been using a borrowed deck and now need for Sony to get these things available asap.
What I like is HDV/DVCAM/DV all in one deck - and downconversion to 720p as well!!!!
This is going to make my life SO much easier
Cheers
Jeremy
MJ Productions
Old April 30th, 2006, 11:06 AM   #14
B & H
Hi Keith,
B & H says they still have the M10U.
Jack
Old April 30th, 2006, 07:07 PM   #15
So, whats the difference between the 15U and 25U? From reading the specs, the only difference is the LCD on the 25U for another 1300 bucks.
Dave
Dave Campbell is offline   Reply
