Could I use a DSR-11 with an FX1 at DVinfo.net
The Long Black Line
Old February 12th, 2006, 01:33 PM   #1
In DV mode to record the longer length tapes to get a 2 hour recording? I'm assuming it can't be used in HDV. Or is there a better deck that does both for this cam?
Mike McKay is offline   Reply With Quote
Old February 14th, 2006, 08:54 AM   #2
You can't record in DV mode on DSR11, just DVCAM. You can use big DVCAM tapes to get 2 hrs or more.
XM2
Sony DXC637P BetaSP
Darko Flajpan is offline   Reply With Quote
Old February 14th, 2006, 11:52 AM   #3
You can record in DV mode, but only in SP. So, it is up to you to
decide if you want to use 83 minute small tapes to master to in DV
or the big DVCAM tapes which will record over 3hrs on the 184mins.
And no, the DSR11 WILL NOT playback HDV tapes. If you are doing
only HDV, I suggest looking to get a Sony HC1 to use as a deck.
Scott Hayes is offline   Reply With Quote
Old March 8th, 2006, 08:03 PM   #4
You can record direct to a laptop, either to an internal or external hard drive, limited only by the size of the hard drive (or battery power, if not powering the cam and/or laptop via AC adapter).
Robert M Wright is offline   Reply
