Hi8 and 8 Capturing
I apologize if this is the wrong forum, but it's tape..:)
Anyways, I have a couple Hi8 and 8 tapes and need to capture them in. So what's the most cost efficient way to achieve this for someone who doesn't have a Hi8/8 deck or camcorder? Also will a Hi8 player/recorder/camera play standard 8 as well? Thanks in advance Patrick |
#2 | |
Also, I understand that if the analogue tape was recorded in LP mode, than the camcorder may not be able to play it back properly. I haven't experienced this because I have been lucky to have only worked with tapes in SP mode so far. So if you get a digital 8 camcorder that plays back the hi8 tapes properly, it should work just like a minidv cam. Just plug the camcorder into your NLE via firewire and import just like usual and your analogue signal will be converted 'on the fly'. Just my recommendation. Good luck. -Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?" - Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974 |
If you just have a couple of Hi-8 tapes and no playback equipment, the best and most economical way to get them played, is to take them to a commercial duplicating company and have them copied to a format you can play. Unless you want to have a Hi-8 or Digital8 camcorder to use, there's no reason to pay for even the cheapest model, for this limited purpose. Actually, the cheapest way to do this is to have a friend with the right playback equipment.
Steve McDonald https://onedrive.com/?cid=229807ce52dd4fe0 http://www.flickr.com/photos/22121562@N00/ http://www.vimeo.com/user458315/videos |
#4 | |
Duh...I feel stupid.....I hadn't even thought of that. It makes perfect sense. Mr. McDonald is correct, I don't think you should consider such an investment if all you need to do is convert a couple of tapes. Finding someone with such a camcorder would definately be the cheapest. You can even send them to me and I will do it for you for a very reasonable fee. (sorry, not meant as a plug -but just lettin' you know it would be at a very considerable savings over buying a cam you would hardly ever need otherwise.) -Jon
