Splitting AVI files at DVinfo.net
The Long Black Line
Old March 8th, 2015, 09:52 PM   #1
Splitting AVI files
Back in the day, I took pains to capture the entire tape into one large AVI file.
Now, I want to split that AVI file into multiple smaller files based on the Shooting Date.
Can anyone suggest a utility that automates this process.
Vince Pachiano is offline   Reply With Quote
Old March 9th, 2015, 03:06 AM   #2
Re: Splitting AVI files
A cheap (free!) and cheerful little prog called WinDV handles the capture from tape, if that's what you're after. The start of every new clip triggers its own label - date and time, plus serial number if more than one clip started in the course of a particular second.
Brian Dollemore is offline   Reply With Quote
Old March 9th, 2015, 09:17 AM   #3
I already have the AVI files captured from several hundred tapes.
I was hoping for a program that would process the AVI files rather than re-import the tape.
I googled SPLIT AVI, and there are several candidates.
They all seem to require that you manually enter the start-stop time of the split.
I was looking for something that would detect the date change, and split the AVI along those lines
Old March 9th, 2015, 10:08 AM   #4
Ah - I was afraid that was the case. Sorry that I can't help.
Old March 11th, 2015, 07:06 AM   #5
Home of AVCutty
Might be worth checking. However, the reports are not clear as to how automatic it really is, and I have not used it.
dpalomaki@dspalomaki.com
Old March 11th, 2015, 11:22 AM   #6
Might ffmpeg work? Cut part from video file from start position to end position with FFmpeg - Super User
https://www.ffmpeg.org/ffmpeg.html
update:
http://ffmpeg-users.933282.n4.nabble...td4469396.html
http://superuser.com/questions/69248...black-frames-s
Jim Michael is offline   Reply
