Help with sony UVW 1800 not recording in color? at DVinfo.net
The Long Black Line
Old November 26th, 2009, 10:39 AM   #1
If anyone knows the uvw 1800 beta sp recorder I am recording to tape and all of a sudden it is recording Black and white.
any help ideas thoughts would be much appreciated!!
Kirk Graham is offline   Reply With Quote
Old November 26th, 2009, 06:40 PM   #2
Are you connected via Composite or Component?
If you're connected Composite, make sure you didn't accidentally connect to the Y connector of the Component input.
If you're connected Component, make sure you didn't mix up/reverse the R-Y and B-Y connections.
Old November 26th, 2009, 08:14 PM   #3
s video
I am connected to the deck via s video and jumping the reference.
Old November 26th, 2009, 08:54 PM   #4
The wires in S-Video cable are 28 gauge or thinner. If the Colour signal wire broke, that would do it for sure. Have you tried a different cable?
Old November 26th, 2009, 08:56 PM   #5
And where are you jumping Reference from? Monitor out? Very badly timed video would do it as well. Have you tried pulling Reference altogether?
Old November 29th, 2009, 03:35 PM   #6
Are you sure your monitor output is setup correctly and that the problem is with the recording?
www.marshallstaton.com
Marshall Staton is offline   Reply With Quote
Old November 30th, 2009, 08:17 AM   #7
Thanks all for the input got it fixed!!
Shaun i tried a new s video and that worked thank you !
it works great now thanks to all who gave input as well !
Kirk
Old November 30th, 2009, 07:56 PM   #8
Yeah, S-Video cables do a Y/C separation (luminance and chrominance) and pass the signals discretely. If the chroma wire (again VERY thin wire gauge) gets damaged (which is easy to do from "yanking" cables) then voila! B&W video circa 1950!
Glad that worked out for you.
