Panasonic MiniDV Tapes
Hi - I've used about 10 Panasonic Professional AY-DVM60YE2B tapes in my Canon XM2 (GL2) (£8.49 for a 2 pack from 7dayshop). I'm working on a serious film project soon and was wondering whether to switch to the Panasonic DVM 63 Pro tapes (£3.42 each from kvjfairdeal).
Question .... Will there be a noticeable difference? If I make the switch, should I clean the heads with a head cleaner tape? Done this once already after one brand switch. Paul. |
The cheaper tape will give the exact same video quality, barring dropouts. I don't know of any evidence that shows more expensive tape leads to lower dropouts. More expensive tape may also be the same quality, just re-labelled and higher priced to make more money.
2- I wouldn't clean the heads. The tape likely uses the same formulation, and it would be ridiculous for a manufacturer's tapes to be incompatible with one another. Also, when using mini-DV cleaning tapes, follow the instructions to a T. Do not clean the camera excessively as it wears away the heads (hence they recommend no more than once every 50 tapes for maintainance cleaning). |
One reason to shoot with the more expensive tapes may be the quality of the tape itself. I find the professionsal grade tapes to be of a high quality in terms of robustness and durablility. The better tapes may not stretch as much or be prone to dropouts as much. But the information recorded on them is exactly the same quality.
Glenn suggests there may be little difference but I don't wish to find out the hard way with original material. I don't know of any tests either that suggest the pro grade tape is better or prone to less dropouts, I just know that I've always been satisfied with the pro grades. My background is film so, in my humble opinion, the best DV tape is a relatively cheap price for peace of mind. |
Well you could figure out the quality of normal tape by shooting a lot of it and seeing how many dropouts you get/notice. Most people shoot lots of tape and don't get dropouts. And when you don't get dropouts, the tape is more or less perfection. You can't really beat that.
The argument I suppose for normal tape is that it is so close to perfect that the dropout rate difference between cheap and overpriced tape is neglible. |
#5 |
Capt. Quirk
One of the main differences, aside from price, the Master Quality tapes are thicker, and hold better magnetic signals. They are less likely to stretch, which would cause dropouts.
www.SmokeWagonLeather.us |
#6 |
I doubt the tape would be thicker, because manufacturers tend to cram as much tape as possible into the cassette to get the maximum length. 60 minutes at normal thickness is the most you can get in there. To get 80 minutes you need thinner tape.
At least that's what happens for other formats like DAT and DDS-1/2/3/4. Do you have a source which says the Master Quality tapes are thicker? |
#7 |
Capt. Quirk
It was most likely DV mag, or it's equivelent. I read it somewhere a few years ago, and it made sense.
#8 |
Thanks guys - shot 7 hours of footage with the AY-DVM60's recently and got 2 dropouts ... thus may switch to the pro tapes.
#9 | |
#10 |
Hi
ME = Metal Evaporated. it's basically how the material is laid onto the tape. Metal Evaporated = good (basically). DVM = something like Digital Video Movie (guess..) 60 = 60minutes available on tape. rgds |
#11 | |
Fred Retread
Linear Plus is marketed as a higher grade of tape. There's certainly no harm in using it. All these product quality differentiations are of questionable value in my book. It's well known that a strategy of marketing the same product at different price levels was used for years with VHS tape to maximize profits by exploiting the psychology of consumers. I use standard EJ tape in my Sony, Panasonic and Canon cameras.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge "My brain is wired to want to know how other things are wired." - Me |
#12 | |
