Editors---Diffrent tape brands at DVinfo.net
The Long Black Line
Old February 14th, 2005, 07:34 PM   #1
I was curious what other editors were doing as far as using multiple brands of tapes from job to job. I mean I know the rule, stick to one brand of tapes. But editors don;t really seem to have a choice. Do you just clean the heads every time you switch brands and that works? Or is there something else? Lucky for me the gig I'm working on at the moment gave me a seperate deck to capture from since they did not shoot on the same brand stock I normally use.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline   Reply With Quote
Old February 14th, 2005, 07:42 PM   #2
In my case, with a DSR11, I will run a tape head cleaner occasionally, because I get different stocks (wet and dry) through it. But because it is a deck, the transport mechanism is by nature, a bit hardier than a camera, so its not as likely to have the same clogging problems with transport and heads that you are going to find in a cam.
Richard Alvarez is offline   Reply With Quote
Old February 15th, 2005, 08:14 AM   #3
Never had a problem with deck. Worked a lot with DSR40 and tapes from 5 camera crews. Off course, they all had different brands of tape (Sony, Fuji, Maxell, JVC and Panasonic - hello mr. Murphy :-))...Never had to clean the heads. Like Richard said decks have more robust tape transports and heads.
XM2
Sony DXC637P BetaSP
Darko Flajpan is offline   Reply With Quote
Old February 15th, 2005, 11:31 AM   #4
Cool, well that was indeed my next question. Can you recomend a deck. Nothing too fansy.
Vlog On!
Old February 15th, 2005, 01:10 PM   #5
I reccomend the DSR 11. About $1600. There are some other dv decks that play SVHS and MiniDV, around $800 I think, but they are hit and miss.
