#541 |
What is your input on the HVR-M15?
Joseph |
#542 |
MPS Digital Studios
The HVR-M15 is less expensive than the M10 or the M25, and it's very good. I work with it all the time, though it doesn't have a small LCD like the other HDV decks from Sony.
heath
My Final Cut Pro X blog |
#543 | |
Why not just use the VX2000 to dump the tape onto your HD and edit from there? This process works well for me, and may serve you well too. |
#544 | |
I want to purchase a Canon H1, but this deck issue is irritating. What is Canon thinking forcing us to use a camera as a deck??? Any clue as to when someone will provide a solution? Thanks! AM
AM |
#545 |
MPS Digital Studios
The best solution is the fun, excellent, full-1920x1080 (resolution) Canon HV20, which records in 24p and can playback 24f and 30f.
heath
#546 |
Heath,
If some find the HV20 not robust enough, couldn't you just get the HVR-M15 and for those occasions where you need to use 24f or 30f, dub from the Canon to the Sony and use the Sony from there on? Yeah, it creates an extra tape, but the Sony deck should be better than the HV20 as a deck. Faster and more accurate shuttlling, etc. Have not tried it yet personally, but that is the general direction that I am going in, though I don't shoot much that isn't 60i. |
#547 | |
Will it stand up to the burden? Thanks!
AM |
#548 |
Alternative to Minidv VCR
I have a Canon XL2 & would like to use it only recording, do not wish to play back on it (may be I am wrong for doing so). It may seems ridiculous but do not wish to hamper the head. To transfer the data & rerecording I prefer a VCR, which is exorbitantly priced. Can you people advice me an alternative, like using a low-end minidv cams/3ccd minidvcam or any other solutions are solicited.
Ashok |
#549 |
Slash Rules!
You answered your own question. A lot of people get a small, cheap, miniDV camcorder for just such a purpose. I don't edit much; right now I have one client I do some editing for, and it's really barely editing at all, and I do my own short films. So a $1500 machine is not practical. I got a Canon ZR500, it's one of the cheapest camcorders they make. I think it was around $250 or so, and it was priced like that new. You can of course, find cheaper on ebay, but those are likely well used. Since the tape heads in the cameras can't possibly be made to stand up to too much abuse, I'd think you would want to look for a new or new-ish one. Anyway, $250 is pretty dirt cheap. Before this I had a ZR80, I think, and that was purchased used for around $200. This is all, of course, assuming you are not doing too much capturing. If you have business and are capturing/shuttling tape on a daily or nearly daily basis, then I think the deck would be worth the investment.
To preempt you and answer another question I've heard a lot, no, it doesn't matter if you are capturing 24p, 30p, or 60i footage. It'll work fine in another camcorder besides the XL2. |
#550 |
Thanks Josh.
Build quality & durability of the mechanical as well as the electronics of the player/cam, Sony is better or Panasonic,since both of them make professional ENG cams. The moving parts should be better compare to Canon's.
I'm considering Sony DCR-HC28/HC38/HC48 or Panasonic NV GS60, can you help me to finalise on these selection or suggest some other. As I told you earlier this is only to use as player & transfer the data to PC, the essential part is IEEE 1394 port for fast transfer. Ashok |
#551 |
Slash Rules!
Couldn't tell you. I went as cheap as possible, and I think someone recommended canon, actually. Like I said, I don't use it very often at all, so it should last a while despite a lack of mechanical quality. As for the electronics, as long as you have the firewire port, you're fine. If it plays miniDV tape as doesn't drop a lot of frames on capture, that's really all you need, I think.
#552 |
So let me get this straight, any DV camcorder with a tape deck and firewire and/or composite ports can be used as a recording deck? The reason I ask is that I wanted to get a portable tape deck, but they're so expensive. So I was wondering, is their any to take out the tape deck, with the firewire/composite ports still attatched, and putting them in some kind of enclosure to make a sony GV-Dxxxx kind of device? If there is a way
The link for the homebuilt camcorder idea: http://www.c-h-a-o-s.com/2007/06/12/...d-a-camcorder/ |
#553 |
I have a project coming up where I will need to capture from a bunch of tapes that are going to be givin to me.(many different brands)
I curretntly use a HV20 to capture my A1 footage but do not want run the risk of messing that workflow up by running a bunch of unknown tapes through the HV20. So I am looking at getting a Sony DSR-11 for this project, here are my questions: When using the DSR-11 will I get drop outs when using different tapes stock? Do I need to run a cleaning tape when I switch brands of tape in the deck? Is there a better suggestion for handling this task? Thanks in advance, Adam, |
#554 |
The dsr-11's I've used were freakin workhorses and we couldn't break them if we tried. Just use some common sense. If your brain is telling you to run a cleaning tape, then just do it, it'll take a whole minute of your life but if it makes you feel better then go ahead.
As a side note, was that the golden age of Sony prosumer electronics? The pd150's and dsr-11's just worked dang it. They were well built and lasted forever. At least the ones I worked with anyway. Now stuff just seems cheaper. Sorry to get sidetracked.
∅ -Ethan Cooper |
#555 |
Has anybody used the JVC SR-DVM600? or know anything about it.
Thanks, Adam |
