The Gigantic Mini DV Deck / Camcorder as Deck Thread - Page 12 at DVinfo.net
The Long Black Line
Old July 7th, 2003, 10:51 AM   #166
Recommended DV DECK for XL1s ????
And you are using the Canon XL1s?
No glitches or jumps?
Help each other for a common good
Robert Ismert is offline   Reply With Quote
Old July 7th, 2003, 12:01 PM   #167
Sponsor: JET DV
I'm using 3 different Canon XL-1 cameras (no "s"). Works just fine until one of the Canon's heads starts to get out of alignment. Then it's time to ship that camera back for repair.
Old July 7th, 2003, 01:17 PM   #168
I use both the Panasonic DV2000 and the DV1000. NEVER had a problem, and I shoot both the XL-1 and the XL-1s. Bob Safay
Old July 7th, 2003, 03:44 PM   #169
what's the difference between the 1000 and 2000?
is it noticable?
I am editing using Premiere 6.5. does it matter how many lines the VTR has? I see that the 2000 has over 500 horizontal lines. will this give a higher quality image than the DV 1000?
Will I get a better image by using my XL1s to export footage to my PC?
Old July 7th, 2003, 06:07 PM   #170
I shoot XL1 and Gl1. No probelms with playback of tapes in tapes in Sony DHR-1000 or GV-D300.
dpalomaki@dspalomaki.com
Old July 8th, 2003, 09:10 AM   #171
If you are recording in LP mode that may give you a few more problems. SP mode should work better (no change in resolution between SP & LP). Some people will use almost any dv device to use as a substitute deck.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old July 8th, 2003, 03:40 PM   #172
There is a BIG difference. The DV1000 is a basic DV deck. Play, record, pause, a few audio ajustments. The DV2000 is an editing deck with frame accurate dials, and the capability to store edit in and out points of multipal scenes, edit scenes, and, it can control either a DV1000 or an LX-1 or 1s via firewire. It also allows you to record video over audio, insert new audio over video, or mix audio. It is much bigger and has a removeable control panal. The end product is truely beautiful. I use it to do my master tapes. Bob Safay
Old July 15th, 2003, 04:17 PM   #173
which deck would you reccomend
the Sony DSR-1800, the DSR11 or the DSR25...
Kyle Baker is offline   Reply With Quote
Old July 16th, 2003, 10:47 PM   #174
_redone_
DVX100 footage from DV deck
is it possible to play back or capture 24p footage from a DV deck that has been filmed with the DVX100? i understand the camera peforms a 3:2 pulldown but does this process take place from the actually filming to tape or from camera to NLE?
Adam Lawrence
eatdrink Media
Las Vegas NV
www.eatdrinkmedia.com
Adam Lawrence is offline   Reply With Quote
Old July 16th, 2003, 10:53 PM   #175
Space Hipster
Yes. Check the resources at the top of this forum for detailed info as this topic is covered in great detail there and in a number of threads.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old July 18th, 2003, 04:55 PM   #176
I don't know much about the 25 or the 1800 but I've had the DSR11 for 6 months now & it's great. Worth every penny.
Erik Selakoff is offline   Reply With Quote
Old July 18th, 2003, 05:41 PM   #177
I may need a deck that has component video output. Any suggestions? DSR-45?
Old July 21st, 2003, 11:14 AM   #178
my DSR-45 has been typical Sony, great so far, 4 months old.
S-video, DV, and component. this has saved me many headaches being able to switch between the source types. no black burst box yet and my Beta 1800 wont talk to the DSR-45, so, straight to S-Video. Plus there is real cool factor to that tiny monitor. its pretty useless for any thing other than video verification, though.
Gary Chavez is offline   Reply With Quote
Old July 21st, 2003, 05:36 PM   #179
<<<-- Originally posted by Gary Chavez : Plus there is real cool factor to that tiny monitor. its pretty useless for any thing other than video verification, though. -->>>
Actually my application would not be editing, but playback of video cues being sent to a projector as part of a multi-media production. I need component video to get the best results with a large DLP projector that takes component as the native input format. The little screen would be useful to preview and advance to the next cue.
Not sure if this is the best route for us, there are also software applications specifically for this but they're probably overkill for our needs...
Old July 22nd, 2003, 08:19 AM   #180
Component output from DV is a waste of time. DV totally sucks compared to any other component recording format.
If image quality is important, put DV at the bottom of your list of possible choices.
Convenience and ubiquity are the only things DV has going for it.
bogiesan
David Bogie
ristretto doppio
My other two cars are a Tour Easy and
a Cannondale.
David Bogie is offline   Reply
