Ising MiniDV Tape in ANOTHER camera THEN putting in good camera again! at DVinfo.net
The Long Black Line
Old July 21st, 2004, 06:38 AM   #1
I have a Canon XL1s and have been using it as a VTR for capturing footage from 7 x 63 min Panasonic MQ tapes. I want to use my friends miniDV cam as a VTR to lessen future wear & tear on my XL1s.
Does anyone know if the lubricant problem or any other issues occur when you put your MiniDV tape in another camera that has dirty heads/mix of lubs/etc. to capture, then put the tape back in the pro camera.
Will lubricant transfer from bad camera to tape to good camera or any other issues that I could face?
Also, how often do you clean your cameras heads? (I have a panasonic minidv head cleaner, cleaned once so far, after recording about 5 hours of footage in smokey bars).
Mark Robbins is offline   Reply With Quote
Old August 1st, 2004, 12:13 PM   #2
RED Code Chef
I can imagine that dirt and other things in the other camera can
stick to a tape and transfer to your other camera indeed.
Rob Lohman, visuar@iname.com
Old August 1st, 2004, 03:10 PM   #3
Just don't use cleaner tape often. Use it when camera tells you to clean heads, if you experience rec/play dropouts or if you changing brands. Too much use of head cleaner can worn your heads quite quickly.
Darko Flajpan is offline   Reply
