Tapeless DV : Seagate to introduce 5 GB HDD CF at DVinfo.net
The Long Black Line
Old June 9th, 2004, 01:50 PM   #1
This compact hard disk can hold almost half of a miniDV tape. I'm really looking forward to a camcorder that nearly eliminates the Capture process, has instant on/off record, and can record with less DV compression.
http://www.dpreview.com/news/0406/04...agate5gbmd.asp
Seagate has announced it is to produce a 5 GB HDD in the CF Type II form factor, although they can't use the name 'Microdrive' that is essentially what this device is. Details at this point are a little thin on the ground, the metal cased device will be available in 2.5 GB and 5 GB capacities, it has a rotational speed of 3600 RPM and features 'RunOn' technology which appears to be a buffering system which avoids data loss if the unit is knocked or vibrated in use. Seagate will also be producing a 'built in' version of the device which is designed to be hardwired into devices such as MP3 players or PDA's. (08:05 GMT)
Gints Klimanis is offline   Reply With Quote
Old June 10th, 2004, 02:36 AM   #2
RED Code Chef
Interesting technology, BUT:
I highly doubt any CF technology is fast enough for DV write rates
or higher rates.
Second: don't expect any of the major brands to do recording to
anything other than (H)DV in the coming years. They will stick to
this compression (in my opinion) for a good number of reasons.
5 GB will get 23.7 minutes of recording time (at most)...
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
