sticking with the same tape at DVinfo.net
The Long Black Line
Old June 4th, 2004, 06:34 AM   #1
Location: Augusta georgia 15min. from Aiken S.Carolina and 2 hours from Atlanta
i have read that it is wise to stick with the same tape, does this mean to stick with the same brand or with the brand and model tape?
i purchased some tapes from circuit city that were wrapped in different wrapping but carried the same model number as my panasonic dvc tapes.
Patrick Falls is offline   Reply With Quote
Old June 4th, 2004, 06:58 AM   #2
RED Code Chef
This question has been answered a lot of times (specifically in
the forum I moved your question to).
Yes it is wise to stick with the same brand and if possible same
type/model tape as well. Some manufacturers have different
lubricants on different "models". This can get stuck on your heads.
Use a cleaning tape if you have to switch but try to keep that
to a minimum if possible.
Rob Lohman, visuar@iname.com
Old June 4th, 2004, 08:03 AM   #3
thanks rob
good info. i've read through the threads on this subject and picked up that i should stick with one brand, but i didn't get clarity on if it was also important to stick with the same model as well as brand. so now i understand that sticking with the same brand is the main objective, and sticking with the same model is secondary. cool, thanks.
