Dv Head Cleaning at DVinfo.net
The Long Black Line
Old December 8th, 2003, 02:42 PM   #1
Dv Head Cleaning
Is it true that using different brands of DV tapes causes your heads to get dirty? If your heads are dirty is it bad to clean them to often? Is it any different to have your heads professionally cleaned than to use a tape cleaning cassette?
G. Lee Gordon is offline   Reply With Quote
Old December 8th, 2003, 03:45 PM   #2
Yes it is true if you mix diffrent brands of tapes it can cause problems dirtying up your heads. Cleaning tapes are not nearly as good as having them professionally cleaned and can actually harm your heads if you overuse them, they tend to be very abrasive. I would reccomend finding one brand of tape that you like and stick with it. If you have been using many diffrent kinds of tapes and are noticing problems you should probably get a professional cleaning and then try to stick with one brand of tape after that.
Jason Casey
www.jcmediaservices.com
www.kickbacktracks.com
Royalty Free Video Production Loops!
Jason Casey is offline   Reply With Quote
Old December 8th, 2003, 04:28 PM   #3
Do a simple search on this site to find more than you ever want to know about tapes and cleaning.
Mike Rehmus
Mike Rehmus is offline   Reply
