DV Tape Rewinder - Page 3 at DVinfo.net
The Long Black Line
Old June 23rd, 2004, 04:49 AM   #31
Thanks for the response Steve....
I may go ahead and use the rewinder based on low use of the tapes as you mention. My record process is this:
1. FF and Rewind the tape just prior to use.
2. Record once and then rewind for capture
I beginning to believe with this short use the rewinder shouldn't have much effect on the tape...
Thoughts anyone?
Mark A. Foley is offline   Reply With Quote
Old July 21st, 2004, 12:56 PM   #32
Sorta off the topic, but a kinda neat trick for anyone out there using Digital8..
As you've probably noticed, a Digi8 camera is RIDICULOUSLY slow at rewinding - i'm sure i coudl hand crank faster.
however it's still a 8mm tape.. got a Hi8 or 8mm camera or deck lying around? stick your Digi8 tape in that and hit Rewind (or FF) presto, nice fast transport! - good luck reading timecode off it tho. :-P
- Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA
+1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com
Mikko Wilson is offline   Reply With Quote
Old September 30th, 2004, 05:38 PM   #33
What mini-DV rewinder to buy???
Well unfortunately, my XL1s has started to eat my tapes when it re-winds. I did a search and there were other folks that have had the same problem. They all say the same thing, send it in to get it worked on. However, right now I can't be without my camera as I need it for some shoots. Until I can send it in, what would be a quality mini-DV rewinder to buy?? I heard that the cheaper ones give you an even greater risk of having a tape eaten up. I need something that will work ...... can you help me?
Jody Hadachek is offline   Reply With Quote
Old September 30th, 2004, 05:41 PM   #34
What about getting a cheaper camcorder? It is a cheap way to get a deck for capturing footage. This will save wear and tear on your XL1. If you shoot a lot, it is a good idea to get a deck (or cheap camcorder) for capturing footage. Repairing a XL1 whose heads have worn down costs several hundred dollars.
Old September 30th, 2004, 05:51 PM   #35
Hey Glenn,
Do you mean buy a cheaper mini dv camcorder to view your footage on, and just use the XL1s for recording purposes? I need the quality of the XL1s for my shoots ....
Old September 30th, 2004, 06:19 PM   #36
You can get a cheap used/second hand mini-DV camcorder to capture DV footage into your computer.
It will give you the exact same quality since it's 1s and 0s being transferred.*
*caveats: There are situations where there are errors in the 1s and 0s being transferred, which causes dropouts.
If you record LP mode in the XL1, it may be that the XL1 that recorded the footage is the best at reading that particular tape. You could/should avoid LP mode and use 80min DV tapes instead of LP mode. Avoid LP mode to avoid these problems.
In other scenarios, the quality of the deck/camcorder will affect how well it reads tape. Head alignment is also a factor. Cheap camcorders might give you problems here- I have a Samsung SCD55 that does this (avoid Samsung). Sony Panasonic and Canon cameras don't have these problems in my experience.
A professional USD$1500+ deck may be more likely to capture DV without dropouts. In practice however, you should find that dropouts are very rare and when they do occur:
A- It's a minor glitch and doesn't really affect final product quality. One dropout is not a big deal.
B- You may be able to re-capture.
C- Visual dropouts are easily fixable with Photoshop magic.
D- Audio dropouts do occur, and they are not easily fixable. However, they are even rarer than video dropouts.
So in conclusion... you should probably get a cheap mini-DV camcorder. I prefer Sony Canon Panasonic just so they have decent deck control and decent quality as a deck (my Samsung does NOT have this). I'd lean towards an old Panasonic camcorder. Old camcorders may have features new ones lack (analog-digital passthrough, bottom loading). Those things don't make a huge difference though.
Old September 30th, 2004, 06:40 PM   #37
Glen,
I really appreciate your input on this. Let me give you the skinny on my recording needs. When I record hunts, I do so on a freelance basis. I don't do any of my own editing or real capturing. I record the footage, and then send the tapes off and the production company will edit at their own desire. So basically, I need something to rewind the mini DV tapes simply to see what I put down and see what else I need to record as supplemental footage. That's it. I know I need to fix the XL1s - but I start filming hunts tomorrow and can't be without it. Do you still think a cheaper mini-DV would work for just viewing/re-winding footage I've put down? Sorry if I'm being a pain with this!!!
Old September 30th, 2004, 06:46 PM   #38
Jody,
Yes, exactly. I shoot all of my footage on my XL1 and never play or rewind anything back in it. For that I use a Canon ZR40, the lowest end MiniDV camera - it replays the XL1 footage perfectly. It is much cheaper than an actual DV deck (not sure about cost of rewinders) and it gives the secondary advantage of being a fine home video camera for shooting things that I don't want to lug the XL1 out to.
Best Buy has this level camera starting at just over $300. Other places will be cheaper.
Good luck.
Barry Gribble
Integral Arts, IMDB
Barry Gribble is offline   Reply With Quote
Old September 30th, 2004, 06:55 PM   #39
Barry ... thank you!!
Old October 2nd, 2004, 11:51 PM   #40
I bought a dedicated rewinder - brand name Kinyo. It cost me about $50 Oz dollars.
http://www.videoguys.com.au/scripts/prodView.asp?idproduct=242
Wayne
If there's no Internet in Heaven, I'm not going!
Wayne Starick is offline   Reply With Quote
Old October 3rd, 2004, 06:17 PM   #41
I am selling a dedicated miniDV rewinder. Bought it from B&H in May, it does fast forwarding as well as rewinding. Email me for pics and more info.
Ronald Lee is offline   Reply With Quote
Old March 18th, 2005, 10:35 PM   #42
tape rewinder
What should I look for in a tape rewinder for my Canon GL-2?
These are mini-DV tapes
Pete Gregar is offline   Reply With Quote
Old March 21st, 2005, 03:56 AM   #43
Generally, I'd advise you to use a cheap MiniDV camcorder as a rewinder/player. The problem with rewinders is that they have no slow-down function, so you slam into the end of the tape hardcore. After a tape goes through four or five runs on that rewinder, you'll have a noticeable degradation in quality.
Tim Brechlin is offline   Reply With Quote
Old March 21st, 2005, 06:12 AM   #44
Would I also be able to use another miniDV to transfer video to my PC?
Assuming it has stereo sound, will the quality be the same as my GL-2?
Old March 21st, 2005, 02:18 PM   #45
Assuming that the camcorder has a FireWire-out port, as almost all of them do nowadays, then yep, you can use it to transfer your footage.
As for quality...well, the footage and audio has already been recorded and committed to tape by the GL-2. It's not like the other camcorder is re-recording your audio or anything like that.
