Grade of tape vs. Brand of tape in my XH A1 at DVinfo.net
The Long Black Line
Old February 19th, 2008, 05:27 PM   #1
I just purchased a Canon XH A1 and am deliberating on what tape stock to use. I'm leaning toward Panasonic simply because I've used it in the past and liked the results.
Now I know that everyone warns against using different tapes in their camcorders, but my question is, what if it is is the same brand? Basically I want to use the Panasonic DVM63AMQ interchangeably with the DVM63PQ. Is this a bad idea? I've read so much on this and can't find a straight answer (don't know if there even is one).
Anyway, any insight is appreciated. Thanks.
Peter Ostrander is offline   Reply With Quote
Old February 19th, 2008, 07:14 PM   #2
This whole tape debate issue has been beaten to death with a stick. I do exactly what you're thinking of doing & have no problems... well yet anyway. I say stick to the same brand, but stay away from much lower quality tape.
Old February 24th, 2008, 06:02 AM   #3
We have 7 cameras and always have used the Panasonic DVM63PQ because they are a dry tape, which I understand the DVM63AMQ is also. Correct me if I am wrong, but I figured that running these 2 tapes would be like running the same tape. The bad part is switching tapes with different lubricants, and in this case there is none.
Jeff Rhode is offline   Reply
