Sony GV-HD700 & GV-HD700E decks at DVinfo.net
The Long Black Line
Old January 18th, 2008, 10:11 AM   #1
I placed an order for this Sony HDV tape deck GV-HD700E (PAL version). I am wondering - does anybody knows what is the difference between GV-HD700 and the GV-HD700E decks? For Singapore domain (PAL) - I don't seem to be able to order the GV-HD700 (only the 700E is available).
TingSern Wong is offline   Reply With Quote
Old January 18th, 2008, 04:55 PM   #2
I believe E stands for Europe. The decks are the same except that non-E is 60Hz NTSC version versus E is the 50Hz PAL version.
P.
Pedanes Bol is offline   Reply With Quote
Old September 11th, 2010, 07:45 AM   #3
Sorry to bring up an old thread but in HD, I thought there is no PAL and NTSC?
Also can this VCR record analogue input from say a SVHS camcorder in HD?
Gan Eden is offline   Reply With Quote
Old September 11th, 2010, 08:09 AM   #4
I am not sure about PAL or NTSC for this tape deck. I have the GV-HD700 here. Working fine for me.
It comes with Firewire S400 input / output. For analog, there is S-Video and composite input (with audio RCA).
As long as your SVHS camcorder can output firewire signals, I can't see any problems for this deck to record in HD signals.
I connect the tape deck to my Canopus NX card and can use it for both input and output of HD materials (on normal mini-DV tapes).
Old September 11th, 2010, 08:47 AM   #5
No, the SVHS only has S-video out and BNC Video out. Its not digital at all.
Old September 11th, 2010, 08:58 AM   #6
I don't have recorders that output analog HD via S-Video for me to test if the tape deck can record HD via S-Video input.
Mine are either HD-SDI or Firewire S400.
Maybe some other members might be able to help you with your inquiry.
Old September 11th, 2010, 03:40 PM   #7
The frame rates differ so you need the correct one for your region.
Also can this VCR record analogue input from say a S VHS camcorder in HD?
No. It will convert the analog VHS output to Digital but the picture won't get any better. It's possible it might put the recording into an HDV wrapper, but it won't really be HD.
Old September 11th, 2010, 09:31 PM   #8
Thanks but I wanted to output the optical image straight to dv bypassing the SVHS recording unit, like a live stream to dv?
I read the Supercam has 700lines.
Old September 12th, 2010, 11:16 AM   #9
Yes, but it's doubtful you'll ever get anything more than 400 lines or so out of those outputs. Possible, I suppose, but not likely.
And your HD700 won't record at more than 480 anyway via the analog inputs, I'm fairly certain.
Adam Gold is offline   Reply
