HDV out for streaming at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old June 8th, 2013, 08:34 AM   #1
Hello, A long long time ago when the HM 700 first came out I remember hooking it up to my laptop and doing a test stream and happy because it worked. Now many years later I was trying to do the same thing and can't remember what exactly I did or find the cable that would make it work. I was wondering if anyone does this now and could help me remember. I will have 2 laptops I will need to make this work with. One a PC wish USB 2.0 and a newer macbook with USB3.0 and thunderbolt. Will the one cable work again or would I need something that can do HDSDI somehow. Thanks
Calvin Bellows
www.exposureproductions.ca
Calvin Bellows is offline   Reply With Quote
Old June 11th, 2013, 08:21 AM   #2
Re: HDV out for streaming
The only way to do HDV streaming is via firewire.
You can also stream via HD-SDI, but you'd need something like the BMD Mini-Recorder to do that.
Mike Squires is offline   Reply With Quote
Old June 11th, 2013, 08:31 AM   #3
You can also use a hardware based encoder and bypass the computer completely.
http://www.bhphotovideo.com/c/product/963061-REG/cerevo_cdp_ls02a_high_definition_live_video.html
http://www.LandYachtMedia.com
Chris Medico is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
