Print To Video w/ HM 700 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old March 22nd, 2013, 04:02 PM   #1
Hello,
Does anyone know the trick to get the HM 700 to see print to video from FCP 7?
I have to do this to feed news packages over Live U backpack when there is no
fast internet available.
On the GY-200, you put the camera in VTR mode and there it is. The recorder begins with a command from
Final cut. Very easy.
On the HM 700, VTR is called Media mode, and it is not seeing Final Cut.
Hope someone can help.
Thanks.
Tim Stollery
Tim Stollery is offline   Reply With Quote
Old March 22nd, 2013, 04:32 PM   #2
Re: Print To Video w/ HM 700
If I follow you correctly, you want to use the 700 as a recorder? Media mode is for checking video captured on an external device, not for recording, if that's what you want to do. Manual quote:
" This (media) mode is used for viewing images input into the {IEEE1394} terminal from an external device and not intended for recording input images on the camera recorder."
I believe only the 790 has a vtr capability.
Old March 23rd, 2013, 01:16 PM   #3
Battle,
Thanks for your response.
It seems odd that the 700 is an upgrade to the 200, but would not have the capability to do print to video.
I understand that video is toast, but it is still a great back-up for worst-case scenarios.
tim
Old March 23rd, 2013, 03:28 PM   #4
I did web video for a large newspaper before I retired, and a lot of what we did required camera-as-vtr for pool feeds and such. I think this is an important capability for any ENG type camera. It is an unfortunate oversight and I think one that could probably be fixed in firmware, although I don't know that as a fact. But the 790 alone has the vtr ability, according to the manuals. Bummer.
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
