IR daylight sensitivity on GY-HM700 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old July 12th, 2012, 08:03 AM   #1
I'm wondering, has anyone either tested or found that a IR cutoff filter is needed on the 700's?? Living in the Northeast US with lots of UV and very bright lighting during the day, I'm considering a purchase of a Schneider 4x4 filter that does both UV & has a IR cut for those times when needed.
Under most cases I'm always using a ND gradient of some value, and I have no UV 4x4's as I've been told (correctly/incorrectly) I don't need one.. Thoughts on that??
What are your thoughts. Is IR a problem for the 700 series in daylight, or a misconception..
This is what I'm proposing to use: http://www.bhphotovideo.com/c/product/567980-REG/Schneider_68_121044_4x4_Tru_Cut_Ultraviolet_UV.html
Steve J. Nordahl
Bethlehem, Pa.
Steve J. Nordahl is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
