GY-HM700 and Fujinon 13x wide lens (video) - Page 2 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old April 25th, 2011, 01:53 PM   #16
Re: GY-HM700 and Fujinon 13x wide lens (video)
The scene file that Pascal linked to, (the Oprina settings,) are basically what I've been using on my 700u w/Canon lens since I got it back in October. I loaded all the presets I could find on here into the camera, and then went out and shot some test footage.
I wasn't expecting the Oprina settings to work as well as they did, because Eugen has the Fujunon lens, but that's what I've essentially ended up using.
It's a good, solid general setup that can be fine tuned a bit to preference, and far better than the factory settings. I hope that will address your noise issues, (and yeah, stick with 720. 1080 isn't as pretty as hoped on the 700.)
But I am interested in seeing what image settings others are using. Mike started a thread back in March of last year as a place to share Scene and Picture files, but it never really took off:
http://www.dvinfo.net/forum/jvc-gy-h...r-setting.html
I'd really like to see some more activity over there! I'll try to post the ones that I've accumulated up there in a little bit.
All the best!
Daniel G. Trout
Fishmonger Media Consulting
Daniel Trout is offline   Reply With Quote
Old April 25th, 2011, 03:51 PM   #17
I also uploaded the video to Vimeo:
Settings I used:
Detail 2
Master Black Normal
Black toe Compress
Compress Level Level 1
Point Level 10%
Knee Manual
Level 90
White clip 100
Gamma standard
Master level -1
R Level 2
G level -1
B Level 1
Color Matrix Cinema Vivd
Adjust
Mg&R Mg Level Normal
Mg&R R Level Normal
R&Yl R Level Normal
R&Yl Y Level Normal
Yl&G Yl Level Normal
Yl&G G Level Normal
Yl &G Mask Range 10
G&CY G Level Normal
G&Cy Cy Level Normal
Cy&B Cy Level Normal
Cy&B B Level Normal
B&Mg B Level Normal
B&Mg Mg level Normal
R Rotation Normal
B Rotation Normal
G Rotation Normal
Color Gain 5
DNR On
My settings are very different compared to Oprina settings, so I'm interested to test out the other.
Derran Rootring is offline   Reply With Quote
Old April 25th, 2011, 03:59 PM   #18
That is some beautiful color, Derran. Thanks for sharing your settings, I'll tinker with that a bit with the Canon lens, and see how it looks.
I can tell you that you might want to avoid using Vivid Cinema on your Color Matrix setting with the rest of the Oprina setup. No one, (including me,) seems too happy with how that looks.
Daniel G. Trout
Old April 25th, 2011, 04:23 PM   #19
OK thanks!
I will start with the complete setup from Oprina and work from there and see what I would like to change. It's really nice to see how much we can change the look with these settings and get a completely different camera.
Old April 25th, 2011, 06:34 PM   #20
I just made the adjustments to mine. I have the Canon lens as well and normal cinema set on mine. Hopfully get out this week and test these settings as well. Steve
Steve J. Nordahl is offline   Reply With Quote
Old April 27th, 2011, 12:40 AM   #21
Thanks for posting your settings Derran.
The colours are lovely on the Tulips. Will give your settings a go.
Keith
Keith Marley is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
