AC Power Supply at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old February 16th, 2011, 02:48 PM   #1
AC Power Supply
Still waiting on delivery of HM700 and I think I have just had another rude awakening as to extra outlay - didn't realise that it does not come with an AC power supply.
Can anyone give me some suggestions as to what is the best option - I am about to buy two SWIT batteries with charger, however would I be better forking out a few quid more for a SWIT charger that can also be an AC supply or should I buy a separate adapter, and if so anyone got any reasonable recommendations?
Thanks in advance.
Keith Marley is offline   Reply With Quote
Old February 16th, 2011, 10:41 PM   #2
JVC America
You may want to look into the IDX VL-2PLUS which charges two V-mount batteries or provides 60W power via XLR, both in the same unit.
Good Luck,
Craig Yanagi - National Marketing Manager
JVC Professional Video Division, JVCKENWOOD USA Corp.
Craig Yanagi is offline   Reply With Quote
Old February 17th, 2011, 03:57 AM   #3
Thanks Craig - it looks better than the SWIT one I had been looking at.
Keith
Old December 12th, 2011, 07:27 AM   #4
Re: AC Power Supply
Hoping for some clarification...
Is it possible to power the camera without a battery?
Christian Brown is offline   Reply With Quote
Old December 12th, 2011, 02:32 PM   #5
Re: AC Power Supply
Yes it is. The charger Craig mentioned also doubles as a power supply.
In my case, I was lucky enough to buy my HM700 when they included an Anton-Bauer battery and charger with it.
I can run it on battery (almost 4 hr.) or stick the charger on and run it from AC.
Old December 12th, 2011, 04:36 PM   #6
Re: AC Power Supply
As Mike said, yes you can power the camera (as most pro cams) without a battery. However you need a charger/ac adaptor to do so. Anton Bauer has a number of different ones (varying price range) IDX has a couple of different ones, not sure who else has that piece.
Here's the rub. At least with the Anto Bauers you can't charge the battery(s) and power the camera at the same time. When I ran AB batteries I used a 4 position intellicharger to charge batterys and a much less expensive Tandem 60 to power the camera IF I needed to have AC and battery power for run and gun. At seminars and focus groups AC power is IMO the way to go but I almost always needed the ability to be mobil for B roll and talking heads so batterys were needed. Having both solved the problem but honestly I could have gotten away with just the intellicharger to power the camera and not worried about charging the batterys since I had 4 of them (at least) on the job at all times.
Don
Old December 12th, 2011, 09:21 PM   #7
Re: AC Power Supply
You could also presumably use the 4-pin XLR DC in on the side of the 700 with a suitable mains power converter (they have them at B&H). I haven't tried it with mine (I have the Anton Bauer charger that others are talking about), but I've definitely thought of using it...
Hamish Reid is offline   Reply With Quote
Old December 12th, 2011, 10:07 PM   #8
Re: AC Power Supply
The AB intellicharger/power supply powers the camera using the 4 pin XLR. I used it on Sony DSR models, my JVC 5000 and 5100 and even the JVC HD200/250 series also had 4 pin power ports. It was actually my preferred method but I found the Tandem 60 worked fine especially if I had to have the batterys available for off tripod run and gun.
Don
Old December 13th, 2011, 11:18 AM   #9
Re: AC Power Supply
Ah, I only have the cheapest possible AB changer -- just the basics :-). It fits on the back of the camera like a battery. Maybe there's an XLR fitting there somewhere but I've never actually looked...
Old December 13th, 2011, 02:22 PM   #10
Re: AC Power Supply
The Tandem 60/70 series charger/power supply doesn't have 4 pin capability.
The intellicharger/powersupply does but can't only be used for 1 function at a time.
The Tandem series can also only be used for 1 function at a time.
Don
Don Bloom is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
